Help with engine noise
My engine is making a sound I cant figure out in the last few days. If you have been around Vortech superchargers when they are being spun at idle engine RPM (not the SQ quiet ones), my engine making a sound exactly like it.
I listened to the alternator and A/C compressor since they are on top but I dont think either one is the culprit. The sound seems to be coming from the middle of the engine possibly below the intake.
I replaced the oil separator a couple of months ago and have not checked the bellow but I am pretty sure that is not it.
Another comparable sound is the A/C compressor on a Chevrolet V8 like Suburbans and Pick-ups when the clutch is engaged.
It does not matter if the A/C is on or not, I believe ruling the compressor out.
It is audible in the cab with windows up or down. 89k miles Tip, any ideas, TIA Cory
You can eliminate all external componants by removing the serpentine belt and running the engine. What oil is in the engine? Is the noise present on cold engine, warm engine, under load? Exhaust system tight?
Newbies Hospitality Director
It is probably your Tiptronic transmission... your engine is rejecting it!
Sorry, I can't help with the real diagnosis, so I thought I would give you a little grief about the Tip, Tippy.
Originally Posted by Tippy
I hate to bump up but I got pushed to the end of the page.
Does the noise diminish under load?
well since a 1/3 of the oil stays in during an oil change, I have a mix of 0W-40, 15W-50, and 10W-30 from past oil changes. I have a super blend, so I have a 8.3W-40
Less than 20% is the amount of oil a normal oil change will leave in the engine.
Originally Posted by LVDell
1/3??? Not sure I agree with that or even the 1/5 that 1999 suggests. I imagine it is close to the 20% if you just drain and fill versus letting the car sit for a while if you have the time (say 1hr plus) you can get quite a bit out, probably close to 90-95% easily.
So, you DO agree with me Dell. I said LESS than 20%.
If I had said 5%, people would have been all over me for starting another oil thread. Additionally, Porsche manual specifically states that only 80% of oil will come out and I don't want to contradict Porsche....the Gods of automobiles.
idler pulley
taake out the air box and start the car, ( use a bugee to hold the fill tube up and off the belt)
start the car
use a scre driver to touch the bolt for each idler pulley
you should be abale to feel it and you can put the screw driver to your ear to listen
beware of spiining parts and belts
start the car
Oh aren't the oil debates fun?
