Extended Warranty Help - 03 C4S
Friends,
I am purchasing an '03 C4S - 20k miles. The following is a proposed extended warranty. Do you think this will cover the major problems that sometimes come up with 996s? RMS? Since clutch is not specifically written, I assume it is not unless you see something I don't. Love to get your opinion on this or whether I should beef it up to bumper to bumper.
Thank you.
Coverage includes:
Engine: cylinder block, cylinder head(s), rotor housings and their internal parts, intake manifold, exhaust manifold(s), timing gears, timing chain(s) or belt(s), timing chain or belt tensioner(s) and timing chain or belt cover, valve cover(s), flywheel or flexplate, ring gear, harmonic balancer, oil pump, fuel pump, vacuum pump, water pump, oil pan, turbocharger or supercharger housing(s) and their internal parts, waste gate, intercooler, engine mounts.
Transmission: Transmission case, transaxle case, transfer case and their internal parts, torque convertor, vacuum modulator, cooler and metal cooler lines, transmission mounts.
Drivetrain Assembly: Final drive and axle housing(s) and their internal parts, flex disc, axle shafts and bearings, universal and constant velocity joints, drive shaft, center bearings and drive shaft yokes, four wheel drive engagement actuator/motor.
Suspension: Upper and lower control arms and their shaft and bushings, ball joints, steering knuckles and spindles, stabilizer and strut or track bars and their bushings and links, coil springs, torsion bars and their mounts, leaf springs and their shackles and bushings, hub bearings or wheel bearings, McPherson struts.
Front Wheel Steering: Steering gear housing, rack assembly, belt-driven pump and its reservoir and their internal parts, steering column shaft and its couplings and bearings, steering pump pulley and mounting bracket, pitman arm, idler arm, tie rods, steering linkages.
Brakes (non ABS): Master cylinder, wheel cylinders, calipers and their seals, power booster, accumulator, combination valve, backing plate assembly, metal brake lines and fittings, brake pedal parking brake assembly. No coverage for ABS brake parts.
Electrical: Alternator, pulley and mounting bracket, voltage regulator, starter motor and its solenoid and drive, wiper motors, manually operated switches, neutral safety switch, backup light switch, brake light switch.
Thank you.
Coverage includes:
while I have no real good opinion on your question, I thought i would say you have an awesome Bully. I have one too and they are just the best dogs!
Good luck with the car, hope those that know give you good advice.
Not the way it's written. I don't see seals (e.g., RMS) and coolant tank (another common failure) being covered. A better type of coverage would say they include *everything* except with a list of exceptions.
Also, the transmission coverage seems pretty weak for a stick shift.
Clutch (and brakes) are out of the question for any type of warranty since they're clearly a wear and tear item and so much usage dependent.
- Ahsai
- Ahsai
+1 with Ahsai.
Few more things:
--Is there a limit on the number of claims per year?
--Is there a dollar limit on the hourly labour charge (some cover $90/hr only) ?
--Is there a dollar limit on parts per repair (some cover only $2000) ?
--Is there an annual cap (e.g. $10,000 per year in claims), like a medical / dental policy?
--Is there a minimum waiting period after the purchase when you can file your first claim?
--Can you get work done anywhere? Call up a few dealers / indies to see if they have worked with this warranty company before.
Few more things:
Ummmm. Lots to think about and research, thank you. RMS coverage for me is a must. Sounds like Coolant Tank should be as well.
I agree, exclusions would be much easier. I'll shop it. Got some time.
I too am looking for an extended warranty and asked my local P-car dealer and they recommended EasyCare. They said that is the only one accept direct payment from. All others, you have to pay and then collect from the warranty company. I am still looking into Warranty Direct and SmartAutoWarranty to get some comparisions. Any feedback or experiences would be appreciated.
Newbies Hospitality Director
Phil - I believe that the coolant tank is NOT covered in MOST instances. However, I recall a few guys getting it replaced by the dealer under what the guys called "good will" from the dealer.
You are going to have to replace the tires from rot before you replace them due to excessive wear. Now, get out and drive that thing.... HARD!
No I have not, but a good friend of mine who has a Boxster S had one 2 weeks ago, his A/C unit stopped working and Warranty Direct covered it no questions asked, the only thing they did not cover was shipping of the new unit from Germany..(cheap)
I know people who had RMS replaced. I choose WD because I have only heard good things about them...
Try this guy..... www.mbadirect.com
Ed Rodriguez
MBA Direct
Tel: (800) 347-0303 ext 329Fax: (480) 860-0867
I have always had great luck with their service and fair prices with great coverage.
eric
Ed Rodriguez
MBA Direct
eric
