Strange fluid leak...
Have you thought about flushung the coolant throught the rear drain plug? Use VW pink antifreeze with dionized water. I did it to mine and it smells like a new car.
Regards,
Regards,
Update- I replaced my cap with the new one, and no leaks (again) for about 2 weeks. Then, lo and behold, two small puddles behind the rear wheel. So I finally replaced the tank (bought from Sunset and had my Indie do it), and since then, I've driven about 1,500 miles, no loss of coolant, no drips, level steady on max line. I thought it was the cap initially, but turns out it was indeed the tank.
Kind of hard to say that the new cap "causes" the coolant tank to go. I had the same issue...replaced the cap, then three weeks later came out of a shop to find coolant pooling under the left rear. Because of all the similarities in both failing within less than a month, I think the evidence more or less strongly suggests you replace the tank along with the new cap. I'm not a big believer in coincidence.
Originally Posted by cadencex
Sounds like a lot of people are getting cracked tanks right after new caps...is the pressure holding in and cracking these things??
This is what happened in my situation.
Newbies Hospitality Director
Originally Posted by ZX9RCAM
I actually think that most people replace the cap "first" hoping it will fix the problem....all along the tank was already cracked & just got worse,
I had the same problem last year. I the tank has turned yellow I would replace it.
2000 Porsche 996 C2 Cab
Eibach springs.
Short shifter B&M.
Fabspeed Exhaust.
Headers
Agency Power Rear Adj. Control Arms
OBC Switch, MP3 Wired.
280 x 18 Pilot Rib
Eibach springs.
Short shifter B&M.
Fabspeed Exhaust.
Headers
280 x 18 Pilot Rib
