Stupid questions re: brake bleeding
Technical Guru
Originally Posted by 02 Carrera
This is not true. You are supposed to bleed the master cylinder at a tap below is and not all the way through the lines when replacing it. This is not a pedal bleed procedure.
![](https://members.rennlist.com/jandreas/996-BrakeBleedWarning.gif)
Just flushed my brakes this afternoon. Motive works great. Vacuum bleeder works great to empty the master cylinder and catch the bleed off since it has all the hoses. Personally, don't think it's worth much more than that. Used Super Blue. Very easy to see the change.
