Should I make the switch from 0W40 to 15W50
#76
Originally Posted by bernocco930S
2004 996 C4S @ 65,000 miles. So here is the bottom line question for me. XXW50 is out of the question BUT is there a no-brainer answer to the question of 0W40 VS 5W40 FOR MY APPLICATION??
Thanks in advance I will listen....... eric
As for the oil debate, I'll just read whatever Mr. Hillary has to say, and follow that advice.
#77
Originally Posted by Doug Hillary
Hello,
1999Porsche911 - as I said earlier I will not be drawn into a debate over the erroneous "facts" that you promote! Your Post number 73 above is just simply full of misinformation and whats more in the last sentence you say this;
"If you don’t want to use 5W50 or 15W50, at least get rid of the 0W40 and more to a 5W40 or higher"
1999Porsche911 - Both the 0w-40 and 5w-40 engine lubricants are SAE40 Oils !!!!!!!!
I strongly advise anybody reading Post 73 to submit it to a Professional Lubricants Engineer (not a Salesperson) or a Lubricant (Oil Company) Chemist or Professional Blender to ascertain the true level of misinformation it contains!
I will not debate this issue with 1999Porsche911 further as after some months and in various Forums on here he has simply spread very little meaningful information but a large amount of harmful misinformation. I won't waste further time or effort!!
Regards
Doug Hillary
Regards
Doug Hillary
I kinda like the way you can lump a 0W40 and 5W40 into both being a SAE40 oil, yet a 5W50 and a 15W50 are NOT both SAE50 oils. Funny stuff Doug.
But like you suggested, why debate, those who care will find the right answer on their own.
#78
1999Porsche911, I'm still waiting to hear your reply from the last oil thread. The thread where you stated "Secondly, rather than living your life reading and following the opinions of others, why not actually do some testing. Then, whatever your position is, at least you have some data to back it up."
I assume this means that you "have done some actual testing" and "at least have some data to back it up".
You continue to advocate different oil for our cars. What evidence do you have to support your position on the proper oil for Porsche 996's? What sort of testing have you done on the Porsche 996? How do you explain those that use one of the oils that Porsche recommends and have no oil pressure problems, do not burn oil, and don't have any valve clatter? What is your answer to published reports by independent Porsche experts that the VarioCam plus system in later cars require "lighter" oil to function properly?
I will not argue oil with you as I am not an engineer or an oil expert. However, you claim to have 35 years of experience. I would simply like to hear any evidence you have (from your testing) that Porsche engineers are wrong? (Hopefully evidence beyond pointing to any number of problems that occur to some people on this board and stating that it must be the oil.)
I am not posting this thread in a negative manner. I would genuinely like to understand why you feel the current Porsche list of recommended oils is wrong.
#79
This is one reason why the SAE40 oil (M1 0w-40) is very well received by Manufacturers and a factory fill with such as Porsche, MB, AMG and etc. It has a successful record in tracked engines and is well endorsed by Factory Technicians. It is a very robust oil indeed
I park in a heated garage. Clearly your data revealed that the OEM recommended fill is the way to go. What was was most exciting however, was the fact that it stayed very competive as a lubricant with 15W-50 at the high temps that you posted. Dare I say that you have closed this case. Any of the other comments are just hearsay and anecdotal evidence. You viscosity measures set a very high bar in this debate!
Thanks a bunch.
#80
Originally Posted by 1999Porsche911
It is amazing how the many years of marketing efforts have saturated the minds of so many, but even more amazing is the number of people who simply accept hype as fact and that, some how, lab results transfer to the real world.
If you don’t want to use 5W50 or 15W50, at least get rid of the 0W40 and more to a 5W40 or higher.
I'm not trying to nitpick you; it just seems that you've not posted any data to substantiate your claims. Can you post before and after photos of engines that have used the different weights of oil?
#81
Originally Posted by nycebo
I presume that you don't like to use Porsche's recommended octane either? Nor their coolant?
In all reality though, this "lifetime" coolant we have in our cars really isn't "lifetime".
#82
Originally Posted by LVDell
Edward, IIRC, this is something that he has addressed and does NOT use the PCNA rec'd coolant but rather change it more frequently using mainstream stuff from Auto Zone, etc..
BTW: I just got back from Chapel Hill yesterday. I was only there for 5 hours on my way back from Miami.
#84
Next time in town, shoot me a PM. I'd be down for a drink, lunch, etc.. Heck we can even talk about oil if you want
#86
Yet another bombing run in 1999Porsche911's ongoing oil crusade.
He visits a thread tells everyone they are using the wrong oil and leaves with no substantiation for his claims.
#88
...that is because there is NO substantiation for his claims...it is all opinion and conjecture...not a shred of real world testing or results. and all experts results and opinions are dismissed as worthless.
#89
Newbies Hospitality Director
I use Mobile 1 oil that flows at the same rate as Aunt Jemima Pancake Syrup (Butter Flavored). Do you think I am hurting my Porsche?
BTW - the Pancake Syrup tastes better than the oil.
Also, I need to change the Winter air in my tires to Spring air. Should I go to the Porsche dealer to get that done or can a tire shop do that for me?
#90
I say start a new thread with that question, it's easily good for 4 or 5 pages... oh yea and mention you want to use N02 instead of air.
