Window problem, Advice needed
This issue relates to the feature that automatically drops the driver window a 1/4 inch when you open the door and puts it back up for a good seal a split second after the door closes. All of a sudden I've noticed that as soon as I let go of the door handle, the window goes back up so that when you close the door, it doesn't seat properly. I then have to drop and re-close the window.
Anyone run into this before ? Is there a way to reset the settings or do you think a relay is defective ?
Thanks in advance.
Ramp.
Thanks in advance.
Ramp.
I too have this issue. I took it to my indie shop and they "re-calibrated" or "synchronized" the windows and it got a bit better. But I still get it from time to time. When I take the car back for it's annual maintenance, I'll have it looked at again.
I would love to hear what might be the cause. The passenger side does not do this and my battery seems fine.
Pete
Pete
Just putting this back on top - need suggestions to fix this problem.
YES!! i have the same friggin problem, please let us know how to fix this annoying problem. if its something i can do, great! if not, ill take it to an indie window repair place to get it adjusted.
I would bet on the regulator, it is a pretty common failure. I replaced mine following this link:
http://www.bombaydigital.com/boxster/projects/window/
I'm bringing this back as I just had my window issue fixed (under CNA Warranty - see the aftermarket warranty thread) - psyched
My indy got the problem on the head - the issue, at least with me, was NOT the regulator but a switch in the door locking mechanism. I have the part and will post a pic later. Not sure if it's a DIY fix for me, but definitely should be for others.
I have to go look at the receipt but I think the price to repair (to the insurance co) was around $300.
FWIW
FWIW
