Boxster S Red calipers
Originally Posted by Kolshak
Dell - if you don't mind me asking, where did you buy yours & did you do the pads & sensors too?
Newbies Hospitality Director
Newport my attention to detail isn't good enough for this to be a DIYer but I appreciate the advice as yours look awesome. Because I can't paint and probably don't want to wait a week or two, I'm trying to determine total cost of a swap with some used/new calipers, pads, sensors, caliper bolts, etc along with the time to do the change.
I still may look into finding someone local (DC) to paint mine because I'm not totally sold on the red calipers with Lapis, Sav. beige and a black soft top combo. Pink might look nice though.
The first pic is a shot of my calipers on my '04 Lapis Blue Coupe.
The second pic is after the final coat of paint and placement of the PORSCHE lettering.
The third pic is after applying a couple of thin layers of spray clear coat.
The whole process took about 6 hours +/-.
No offense to Tim's great handy-work, but if I was going to "paint" them like Tim did, I would take them OFF the car so it is easier to be "perfect" with the paint and to not have to work about masking, etc, of parts that you can have removed. Not to mention you would have the ability to THOROUGHLY clean them prior to application. But that's just me. Hey, blame it on the OCD!
Now you understand why I went with the factory painted calipers instead.
When I bought my 02 996, I ordered Red 996 Calipers from the parts counter. Here in the US they are used on the Boxster S, but have 996 part numbers.
They were about $320 a piece back in 2002. I reused the caliper bolts, but I added a drop or 2 or loctite to each bolt to keep them in place. Everything else came off of the Black calipers.
When I got the new car home, I switched out the black calipers for the red ones, cleaned the cosmoline off of the black ones, and sold them on ebay for $300 each. Net cost for the retrofit was $80.
In 2003 PCNA started offering red calipers on the 996 as a $1800 option. I think the parts counter retrofit is cheaper and you end up with the same thing. Do you need the P/Ns for the Red 996 calipers?
I would guess that you might be able to get as much as $250 a caliper for your black ones. Clean and polish them up and see what happens.
Great, thanks!
For people who are considering them, they are now about $360 for the fronts and $300 each for the rears directly from porsche parts department. There is also someone selling the red OEM rears on ebay for $150 each. Depending on your luck you may get $550 - $800 for black calipers on ebay.
Thanks for all the info & pics everyone.
Tim - the red calipers definitely look hot on your Lapis coupe.
Looking at attached pic, do you think they'd be too much mixed with Lapis, a black top and lighter interior?
If not & I can do the retro as efficiently & cost effective as Orient it's a no brainer. Of course it will probably cost more in the long run becasuse I'll want different wheels so I can see them better.
I emailed the ebay seller who has the "new" ones listed for 150.00 & still waiting to hear back.
