996 Forum 1999-2005
Oil Change
Old 02-24-2007 | 05:00 AM
Porsche_Smile's Avatar
Porsche_Smile
Originally Posted by cdodkin
You should try driving up 4 at once!
Now that's scary!
i don't think you need to jack up your suv to do an oil change do you.....?
Old 02-24-2007 | 12:55 PM
cdodkin's Avatar
cdodkin
True, but if you have it on ramps to do diffs, T-case and auto trans fluid, you may as well do it while you're immobilized.
Or should that be im-Mobil1-ized!
Old 02-24-2007 | 01:53 PM
Botsy67's Avatar
Botsy67
Sorry for this quick thread hijack but what is the torque Spec for the oil drain plug? Did a quick search with no specific answer. I have not changed oil on my Pcar yet, just getting ready Thanks much...
Old 02-24-2007 | 02:04 PM
LVDell's Avatar
LVDell
Bao, 37 ft-lbs for the drain plug and 19 for the filter cover.
Old 02-24-2007 | 05:51 PM
hi8ha's Avatar
hi8ha
Thanks for the info on the Rhino ramps
Old 02-25-2007 | 02:29 AM
Botsy67's Avatar
Botsy67
Thanks Dell for the torque Spec info,... taking notes , greatly appreciate it.
Old 02-25-2007 | 09:43 AM
LVDell's Avatar
LVDell
very welcome
Old 02-25-2007 | 05:25 PM
hi8ha's Avatar
hi8ha
One last question, I hope, can I put the 9 qts of Mobil 1? Don't think that the extra 0.02 qts (911 Carrera 3.4 liter engine oil capacity is 8.98 US quarts) will do any harm.
Old 02-25-2007 | 06:01 PM
LVDell's Avatar
LVDell
I usually put in about 8.5 and then start it up, let it run for a minute, wait about 15 min then check the oil level with both dip stick and electronic measurement. If I show ANYWHERE close to full then I am done. I check in the morning one last time to let ALL the oil drain down. The last thing you want to do is OVERFILL.
However, if you do overfill, there is a way to remove a small amount without doing a full drain or going anywhere near the drain plug.
Old 02-25-2007 | 06:10 PM
DCP's Avatar
DCP
Dell is right on this one. You are not going to get every drop of oil out of that engine, so don't just put 9 quarts in it. You will overfill.
Old 02-25-2007 | 09:26 PM
hi8ha's Avatar
hi8ha
Thanks guys, will do the 8.5, wait the suggested time and take it from there.
Once again, thanks.
Although I'm new to these forums (yes these, rennlist is not the only web-forum/website I visit) I do think LVDell is entitle to his oppinion, is very helpful and should continue posting on the 996 forum.
Regards
hi8ha
