DIY: Optima battery hold-down bracket
Sorry, can't figure out how to get these photos to display rather than link.
Here's what you will need:
A 28" length of 2" wide, 1/8" thick aluminum stock
A 2" long M8 bolt with 2 washers, 2 nuts, and 2 lockwashers
A gallon (or less) of Plasti-Dip or equivalent
STEP 1: Cut stock to length, then bend in the following dimensions:
top = 10"
sides = 7"
left side lower tab = 2.5"
right side lower tab = 1.5"
Use these pictures as a rough guide:
Left side, drill a oblong hole about 1" long and 1/2" wide closer to the terminal side of the stock and starting 1/2" from where you made your bend.
http://img241.imageshack.us/my.php?image=img1681cl8.jpg
Right side drill a round hole 1/2" diameter right after the bend in the same position as the other side.
http://img258.imageshack.us/my.php?image=img1683sx9.jpg
STEP 2: Coat in Plasti-Dip. This creates a rubber coating which is useful to have when you're mounting something so close to the terminals. 3 coats was enough for me and didn't cause any problems with the resize of the dimensions. Be sure to sand the surface a bit rough first before coating so it sticks, then let dry for a few hours between coats for a uniform finish.
Coating
http://img211.imageshack.us/my.php?image=img1684zw8.jpg
Finished product
http://img161.imageshack.us/my.php?image=img1687zt1.jpg
STEP 3: Remove the stock battery tray. On the right side there's a convenient non-threaded hole. This is where you want to mount the stud with the M8 bolt. Put the bolt through the underside and secure with the nut and lockwasher. There's a gap under and over the tray - almost like they were asking for precisely this. There will still be sufficient thread to put another nut on top when you mount the bracket.
http://img255.imageshack.us/my.php?image=img1689df4.jpg
http://img255.imageshack.us/my.php?image=img1690be1.jpg
STEP 4: Disconnect the battery, put the bracket on top, and secure on each side. The stock bolt will fit in a new hole on the factory tray which is close to the new battery location.
http://img444.imageshack.us/my.php?image=img1694nm5.jpg
http://img263.imageshack.us/my.php?image=img1695qu0.jpg
http://img297.imageshack.us/my.php?image=img1696xf2.jpg
That's it. It was pretty easy, and truly looks like a factory job. There is no chance that this battery will go anywhere now, and I feel more secure throwing the car around corners now. The other options just weren't working for me.
I hope this helps more people use these great batteries that may have previously been put off by the lack of options as far as mounting is involved. Anyone has any questions, feel free to ask.
Regards
Signed: Chief "Pic Patrol" Officer
BTW - I do make killer Cream Puffs! I really do!
where did you buy the aluminum stock from?
to post images you need [img] full path to image location [/img]
lets give a try
