996 Forum 1999-2005
How do I flush all coolant/water from the cooling system?
Old 02-10-2007, 09:47 AM
BReyes
BReyes's Avatar
Default How do I flush all coolant/water from the cooling system?
How do I flush all coolant/water from the cooling system? Does it need "Porsche " type coolant only like beemers use only the blue.
Regards,
Old 02-10-2007, 09:58 AM
1999Porsche911
1999Porsche911's Avatar
Unless your cooling system has been compromised, there is no need to flush the entire system. I remove 2 gallons of coolant each time I change the oil by simply removing the coolant plug on the back of the engine. This removes 2 gallons of coolant. I then refill with Peak lifetime 50/50.
http://www.peakantifreeze.com/peak_g...time_5050.html.
This procedure is quicker and eliminates the risk of breaking hoses and other connections, removes contaminants and ensures that fresh coolant is always in the system. It also eliminates any chance of the water pump running dry as occurs when flushing the system.
If you do want to drain the entire system, put aside several hours as the underbody panels must be removed along with hoses, etc and pressurizing the system is necessary.
Old 02-10-2007, 10:23 AM
BReyes
BReyes's Avatar
She ran a cool 180 degrees yestterday evening on the interstate. I think all is well. Runs few mm past 180 deg normally. Want to do that a couple of times. Is it possible a pic of that plug?
Regards,
Old 02-10-2007, 10:31 AM
1999Porsche911
Regards,
Actually, your car will never run at 180F (even in sub zero temps) except as it passes by that point in it's way higher. Target coolant temp is 194F and that temperature can be maintained as long as the car is moving at around 60 mph or faster. Otherwise, coolant temp will be higher, Stop and go driving will bring temperatures to 215F+. Your gauge does not accurately reflect coolant temperature.
Old 02-10-2007, 10:47 AM
BReyes
BReyes's Avatar
I have been watching that gauge for last 1500 miles. Been running a few mm over 180. Was cruising on interstate 50mph 20 miles then maybe 60ish. Dusk. It ran at 180. And then ran back to few mm over 180. Thanks for your statment however.
Old 02-10-2007, 10:56 AM
1999Porsche911
Like I said, the gauge is not accurate. Your car's engine cannot run even close to 180F.
Use the climate control screen to look at the actual coolant temperature. To see it, do the following:
Press and hold in the recirculate and the top (arrow up) buttons on the right side of the panel for a few seconds. The left screen will change. Using the + key below that screen, adance so the display reads 6c. Then press the center vent button once. The display will show you your coolant temp.
To go back to normal, simply press AUTO.
Old 02-10-2007, 10:57 AM
Kevin H. in Atl..
Kevin H. in Atl..'s Avatar
On your temp gauge, the "tick mark" to the left of the 1 in 180 = 180F. If your needle is plumb (straight up and down), your engine is probably somewhere around 195F.
If your needle moves to the right of the zero in 180, your coolant temp is in the 210's.
Old 02-10-2007, 11:03 AM
BReyes
BReyes's Avatar
We are getting somewhere guys. I have some checking to do. My memory (I am not going outside for an hour or so) serves me right it was up and down at what I called 180. I dont really like the sound of the 210 ish number. Been responsible only for air cooled cars for last 7 years so have to become better versed in my water cooled motor too.
Old 02-10-2007, 11:14 AM
1999Porsche911
When it is 70F+ outside, and you are just driving around town, you'll likely see 220F+. I've seen it as high as 230F. The car simply has insufficent cooling surface and airflow, but doing my fan mod will guarantee the coolant temp will never see above 200F..
Old 02-10-2007, 11:17 AM
BReyes
BReyes's Avatar
Do you have more info. 230 to 200 is important to me.
Thanks again.
Old 02-10-2007, 11:19 AM
1999Porsche911
Thanks again.
Radiator Fan and Engine Compartment Fan Switch Mod
The 3.4 996 runs extremely hot when driving around town in temperatures higher than 75 degrees. This mod is a way to reduce coolant temps back to a safer level, helping to reduce oil temps and improving performance.
The mod consists of installing a switch that will allow you to turn on the high speed radiator fans at any time, while maintaining the automatic operation of the fans. We do the same for the engine compartment fan.
Radiator Fans
Connect a wire to the ground of the 2 high speed fan relays located on the relay carrier located in the driver’s side foot well. The relays are #20 and #22. Feed this wire to where your switch will be located. Connect the wire to one side of the switch. Connect another wire from the other contact on the switch and then connect the other end of this wire to a chassis ground point.
With key on, this switch will now immediately turn on both radiator fans providing maximum cooling. When you turn the key off, the fans will continue to run for about 5 seconds until the relay shuts down. Your fan operation remains normal when the switch is off.
Old 02-10-2007, 12:13 PM
evansaero
evansaero's Avatar
Regards,
You can use G12 (Pink/Red Stuff) coolant that Audi/VW uses it's the same stuff that porsche now uses.
$18 bucks a gallon
Old 02-11-2007, 02:39 AM
rleeq
rleeq's Avatar
I’m curious about the use of the AC panel to display and/or change settings. In another post you mentioned a way of display the unmodified speed by activating the climate control screen. Do you have a list of functions that can be preformed by this system?
Old 02-11-2007, 10:26 AM
Kevin H. in Atl..
Here's a link to Christopher Brown's page listing the majority of the codes:
http://www.cb-racing.com/boxster_AC.html
Chris works ALMS Series (and Grand-Am i think) for Motec.
Old 02-11-2007, 10:35 PM
C4CRNA
C4CRNA's Avatar
My 2001 C4 will not give me the numbers on the AC control unit !!It just displays 25c I can't get the numbers to go up or down??
Quick Reply: How do I flush all coolant/water from the cooling system?
