Best offset for 996 C2 - 99
What is the best offset to use on narrow body - 996 if You dont wanna use spacers ? Back 18x10 ET 65 and Front 8x18 ET 50 , is that correct ?
//Rob
//Rob
Front 8x18 et 50 would be satifactory, 8x18 et ~46 would look better, imho.
Rear 10x18 et 65 is factory fitment. I added 15mm spacers to this wheel. So, the equivalent wheel no spacer would be 10x18 et 50. This fills the wheel well much better. Or you could go to an 11x18 et 63 providing that you have enough inner clearance available (this wheel would be 11mm closer to the strut than the 10x18 et 65).
http://www.1010tires.com/WheelOffsetCalculator.asp
