Rear Negative Camber on stock control arms
Just curious how much negative camber you can get in the rear of a 996 C2 on the stock control arms.
This would be assuming ride height of 128mm in the rear (GT3 height).
Trying to determine if the adjustable control arms are really worth it or not when I'll probably set the rear and leave it.
Andy
Andy
I'm installing suspension with camber plates in front which will eliminate the negative camber issues in the front of the car
Besides ease of use why do soo many upgrade to the agency adjustable control arms. I can see the merit if you can only get -1.5 to -2 degrees of camber in the rear of the car without them...but is there something elst that I'm missing besides possibly increased feel from the solid mounts?
Andy
Andy
The rear end of my car maxed out at -2.2 (left) and -2.3 (right).
Andy
Andy
The other alternative is GT3 control arms which not only eliminate the suspension rubbing issue, also increase the track. In order to run them on a regular 996, you need to run them RSR style with the right control arm on the left and the left on the right mounting the torque arms in the offset holes.
I'm going the JIC route soon. (still trying to decide on spring rates)
On my previous car I had to do adjustable rear control amrs to get the negative camber values that I wanted for the track as there wasn't enough adjustment in the stock setup. Sounds like I can get the values I'm looking for with the stock arms on the 996 for now. If I feel the need to upgrade later to the adjustable units I can.
Andy
Andy
