Getting new engine. '03 996 C2 w/22K miles
Originally Posted by 99firehawk
reman you will not a get a new engine, with that said
how many people have had more then one engine replaced on the same car ?
probaly less people have had reman engines fail then their original
i can assure you its not new it is a rebuilt engine
but
every thing inside is new
heads cams chains valves pistons bearings rings seals evrything new except the case and the crank
but
What is the difference between a new engine and a remanufactured engine?
How & why does PCNA stock remanufactured engines? From my understanding, you get a new engine in a new car, and the only time you need another engine is when your current engine goes kaput. There exists no other reason to buy, sell or trade engines, except a very very small % of people who swap engines for power, etc. So, in fact, are you getting a blown engine from some other car that has been refinished to work again?
Originally Posted by jkb
i think its new, let me double check.
Sincerely,
Macster.
my service adviser claims its a new engine, not remanufactured one. i trust him. but i have also asked him for an engine serial number. i will absolutely NOT accept a remanufactured engine. you dont get used part when something else is replaced under warranty. why should engine be any different???
Dude, it's not used, it's reman. Just get PHOTO verification of the number and go from there. But you are not getting a new crate motor, trust Brad on this one.
I have no experience with Carrera remanufactured engines, but those that have received remanufactured for their Boxster report almost unamiously good things.
Sure, there have been one or two that have had the remanufactured engine go belly up, but replaced again under warranty.
For the overwhelming majority, they report their remanufactured engine has been as good as or even better than the original engine, even before the original engine started its decline.
However, you're certainly entitled to object, if the engine proves to be remanufactured (if it can be determined without question is is remanufactured), and request a new engine.
I will point out that with a new engine you are 0 for 1, so another new engine may mimic the first new engine's failure.
Best of luck to you regardless if you decide to live with the remanufactured engine, or if you successfully get a new engine.
Sincerely,
Macster.
This seems to be happening more and more to the motors which were supposed to be "new and improved" as time goes on. Some used to claim that the 02 and on were "safe" due the being excluded from the problems of the 99-01 3.4 litre. Seems that as time and miles catch up to these cars, more are having trouble. At least your 03 is still under warranty, but I am sure there are many 03's out there that are already out of warranty.
This makes me sad. I really was hoping the problem that myself and others had with the 99-01's was going to go away.
your gettins a new reman motor. YOU WILL NEVER EVER EVER get a new engine from porsche. I Can assure you if people with brand new less then 3 month old cars and cars with under 2000 miles have gotten reman motors even after fighting for months for a new one your 03 with 20k is gonna get a reman.
YOu dont have a choice in the matter. you can fight all you want but all that does is eat up time you coudl be drivign and enjoying the car, porsceh is under no obligation to give you a "new" motor. AND they wont
Its also kind of hard for them to keep an unlimted supply of 2003 motors laying around dont ya think.
The x is only in the part number its not in the serial number
it will not affect resale in a negative way
You motor will be all new pistons rods vales springs cams rings bearings chains seals pumps
harness sensors everything
but the crank and the case which will both be reconditiond, you will get all the updated latest and greatest parts which makes it way better then getting an new 2003 motor with the same weaknesses thats been sitting in a warehouse for 4 years .
Dont fight it just smiel and be glad it happened under warrenty
http://www.renntech.org/forums/index...c=4337&hl=Jean
Brad is right with 1 exception. We have a local 2000 Boxster owner out of warranty that did get a new engine, but only because Porsche did not have the correct remanufactured engine in the US, and it was a unique case.
Somewhere I have a picture of the box it came in and there was no X in the part number. Plus I know the mechanic that put it in, and had to be rewired because it was a tip engine going into a manual transmission Boxster.
out of warrenty i have installed new motors, if you hit somerthing in the road and break the block the core is no good so a reman motor is more expesnive including the core charge 3000$ then a new motor
Originally Posted by Macster
the engine serial number, while a new engine will not have the x.
Sincerely,
Macster.
Sincerely,
Macster.
Hey there,
Its done!
The engine # is M96/AT66566662
i guess it is a new engine after all and not reman
Better to visusually inspect it to verify. But as Brad and others have pointed out, chances are slim to none that this is a "new" engine. They don't just have "new" 03 motors sitting around. My guess is that your SA left off the X since it is NOT a numerical value.
