Alternator problems get worse, need help
Shop from hell experience:
Well, after having my car all day yesterday and ordering the headlight switch they said was pulling a draw from the battery. They did not call all day today. I went to the shop after 5pm and they had just switched out the headlamp switch and a couple of the guys were suppose to be "testdriving" it. I found that a bit suspect because they called them twice to tell them I was there... But whatever. It was apparent they had not touched the car. The guy told me I definitely was not getting my car beck today. So I ask why, and he looks at me and says I need to ask someone else. But if he doesn't know, then how does he know it is not fixed?
The guys return and tell me that I probably need an alternator. The exact thing I brought it in for??? and it took them 5 hours and $700 to tell me that and switch out the headlight switch; Which has been like that for over 6 months without incident, I htink most likely a small and insignificant problem. When I ask why I need one now, when they told me yesterday it was fine? No answer. They then say it could be a bad wire to the alternator. Why couldn't they see that yesterday? My *** is tingling, telling me to get the hell out of there...
I tell them that I will get it fixed somewhere else. NOw the one guy says he wants to try something: he wants to switch out the battery to see if it has a fault? I say no thanks. He then persists, and I say fine, then he says they decided not to do that????
I take my car and 1 mile from my house all of my warning lights start blinking and the lights dim, so I turn off headlights and luckily make it into my garage.
He said the new reading is that amps are fine but volts screwed up. I will attach the receipt. Any advice? Is the alternator a do it yourself job? I saw it for under $300 online. Or should I take it to the dealer and get fleeced again?
HELPPPP!!
HELPPPP!!
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
I really think it's your alternator, and yes it's a DIY job, it will give you screwy results with warning lights like gremlins have invaded your dashboard.Your alternator should put out 150 amps.and more than 11vlts more like 13-14. If you whack a bad alternator with a pipe it may give a charge for a while then crap out later.The brushes(voltage regulator) are not engaging in the alternator they are sticking. you have to change the alternator.
Originally Posted by Einstein
chek my website for instr on how to test your alternator. also install a volt gage. see my web site.
Einstien - Good info on your site. I have archived some of it for future use. Thanks for sharing.
