Headlight Issue - Switch or Lamps?
On my 02 C4S, it'll sometimes take 3 or 4 turns of the dash headlamp switch to get the lights to turn on.
Anyone experience anything similar? Likely an issue with the switch itself or is there a common issue with the lights themselves that I need to be aware of?
And...how easy a job to replace the switch if that's necessary?
Thanks all.
Thanks all.
sounds like a headlight switch
replacement is
pull the **** and press the release under with a small screw driver or pick
remove 3 t20 torx screws
remove vent assy
un plug switch
remove 1 19mm nut holding swith on
tun 1/16 turn and remove switch
install is oppisitie
replacement is
remove vent assy
un plug switch
I've got the same problem. Sometimes I can't get them on at all, so I run with parking and fog lights. I'm due for a 15k inspection and am still covered with warranty so I'll let the dealer take care of of it. Figured it was a switch.
