High-speed stall?
#46
Originally Posted by 1999Porsche911
It is located on the left side of your 99C2 throttlebody. It is the larger of the 2 devices on the left side. Remove the electrical connection and then the 2 screws that hold the ICV onto the body. Careful with the gasket as you will reuse it. Remove the ICV and saturate with carb cleaner. Carefully move the vertical valve inside it to make sure it is not stuck. Reinstall and you are good to go.
Jim
Jim
Thanks for your help on this, looks like a great afterwork activity for me.
Is there a way to manually reset the check engine light?
Thanks,
#47
Originally Posted by cohare
Jim,
Thanks,
Thanks,
Be sure to have your radio code handy though, as you will need it.
#49
1 Post
I have a code reader I bought from Autozone, also Autozone will read and reset your check engine light for free.
Jim,
Thanks,
Thanks,
#50
I purchased a reader from them as well to read & reset my own.
#51
1 Post
At first they used to let you borrow the reader buy you just leaving your license, then they started doing it themselves but the last guy I used didn't know how to reset. I showed him how since I use to borrow their device and now this? Zesh.. It's good to have your own.
Originally Posted by ZX9RCAM
The Autozone near my house will NOT reset the codes for some reason, only read them for you. They stated they were not supposed to.
#52
So....I did a little testing and I have nailed down the speed at which the idle goes erratic to be at 53-55 mph. I need to pick up something to read the codes at that point. Will a standard 'autozone' meter read the codes while live or do I need something more sophisticated?
#53
Jim
Jim
I took off the ICV valve and sprayed it with carb cleaner. Then I took a couple q-tips and reached inside the valve and pushed on the valve and it was indeed stuck. The Carb cleaner and a gentle push with a qtip and it was moving freely. I then unhooked the battery to reset the check engine light.
Took her for a spin ~ 30 miles of stop and go, high speed, no stalls and runs like new. Thanks for your help Jim!
