996 Forum 1999-2005
Ok, NEW problem
Old Dec 30, 2006 | 04:04 PM
arr0gant's Avatar
arr0gant
Default Ok, NEW problem
1st off, I need a new battery. Can I buy one from an auto-parts store. I need my car for New Years Eve.
2ndly, I need the Code for my stereo, which I DO NOT have. Anyway I get it today?
Thanks guys!!!!
Gant
Old Dec 30, 2006 | 05:10 PM
SMR996's Avatar
SMR996
You might check under the hood of your trunk. My radio code was written on the paint label sticker located on the underside of the hood....
Hope this helps.
Old Dec 30, 2006 | 05:16 PM
Kevin H. in Atl..'s Avatar
Kevin H. in Atl..
Yes, you can get a battery to fit your 996 at auto parts stores. Sears has one also.
Old Dec 30, 2006 | 05:17 PM
viperbob's Avatar
viperbob
Former Vendor
Auto parts will have one, but try Sam's or Costco and go for an Optima... At least, try for an Interstate.. I can't get a radio code until tuesday... Sorry
Old Dec 30, 2006 | 05:32 PM
LVDell's Avatar
LVDell
Mine doesn't require a code. When did they stop using them?
Old Dec 30, 2006 | 06:02 PM
DCP's Avatar
DCP
Perhaps with the MOST change? My 03 does not have one.
Personally, I can't imagine anyone really wanting to steal one of these.
Old Dec 30, 2006 | 06:09 PM
LVDell's Avatar
LVDell
exactly. IIRC, the 2002model year was the last of the non-MOST radios which would explain the code Gant needs.
Old Dec 30, 2006 | 06:16 PM
Wellardmac's Avatar
Wellardmac
Gant, I replaced mine this summer and bought a Bosch Premium Gold battery - it's holding up well under trickle charge in the garage. I bought it from Pep Boys.
Old Dec 30, 2006 | 07:01 PM
newport996's Avatar
newport996
Did you get all of your original manuals? My code was on a plastic card in my manual.
Old Dec 31, 2006 | 12:31 AM
Ucube's Avatar
Ucube
Like others have chimed in already, a replacement battery is readily available at your local auto parts store. As with the radio security code, just call your dealer's service dept. They'll have you push a couple of buttons on the faceplate to get the serial #, and with that, they'll be able to retrieve the code for you. It took all of 5 minutes when I had it done long ago.
Old Dec 31, 2006 | 12:41 AM
Nicolaasdb's Avatar
Nicolaasdb
check the radio...sometimes the code is written on it...you have to take out the radio to see it!
Old Dec 31, 2006 | 09:32 AM
C4CRNA's Avatar
C4CRNA
I believe that the optima is better and lighter but needs modification to the battery tray to fit. Search the battery installation posts for help. Also you need a vent tube like the original!!
Old Dec 31, 2006 | 10:15 AM
99firehawk's Avatar
99firehawk
turn the key on radio says code, hold the tp button untill it beeps and says becker scroll trhough the display until you get a serial number, wriet down the srial number and pm it to me and ill get youd code for you
Old Dec 31, 2006 | 10:41 AM
Wellardmac's Avatar
Wellardmac
Define better. Better depends upon the use. Sure if you're tracking your car (which Gant does not), then the optima is the better battery. if you do not, then it is wasted money, as the only things that matter are warranty and cold cranking amps. Just a clarification.
Old Dec 31, 2006 | 12:51 PM
C4CRNA's Avatar
C4CRNA
Isn't the gel (optima) battery less likely to lose it's charge due to inactivity? If ruptured in a crash won't send liquid acid all over the place.
