Wheel repair in Tampa ?
Does anyone know of a trustworthy wheel repair shop in the Tampa bay area ?
At the very least, a trustworthy balancing place ?
I need to determine if my 996 18" rear wheels are indeed bent (dealer said they might be, but not much) or if it's just a tire issue, then see if I can fix them.... Thanks !
There is a shop in lakeland that does phenomenal work.
They charge a flat rate of $250 per wheel which includes repair,refinishing, mounting and balancing etc...
It's not as affordable if your wheel isnt bent but the wheel comes back as being brand new.
If you are interested send me a PM and I will give you the info.(I dont have it off hand)
The guy's name is Jeff and his number is 813-842-9181
I am not 100% sure what his buisness was called but I know he does phenomenal work.
I hope everything will work out for you!
-Keith
-Keith
