Is this a clutch problem?
I have a 02' 996 C4 Cab with about 38,000 miles and I went to pass someone on the freeway tonight and a strange thing happened (no I didn't get shot at). When I rapidly depressed the accelerator in 5th gear, the revs went up, but the car didn't accelerate. There was a significant time lag before the car accelerated.
I then began to wonder (WTF) so I tried this in different gears and again the same thing. Sometimes the revs would go up and then once the car sped up, the revs would go down while the car speed seemed to try to catch up to the revs.
There was no problem with moderate acceleration and a slow depression of the pedal, but when I floored it it seemed the engine would go but the car wouldn't for a while. I apoligize that I have very little mechanical knowledge, but does this sound like a clutch problem?
If so, does anyone know a ballpark figure of how much it would cost to get this repaired at the dealership?
Or, what else could this be?
It figures that this would happen just as I am getting ready to sell my @%$#&!! car.
Thanks in advance for all of you mechanically inclined!
Thanks for the feedback.
Time to call the local independent shop.
I don't know about everyone else, but it seems that it is just one problem after another with the 02' 996 (I guess I shouldn't complain since I haven't had an RMS leak or any major engine or drivetrain issues).
I looked at what I spent over the last year on tires, insurance, maintenance and repairs and it averages to about $400/month. I'm not complaining, but the next Porsche that I get will probably be a new vehicle lease so I can get rid of it before the warranty expires.
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
Originally Posted by 99firehawk
"seems that it is just one problem after another with the 02' 996 "
clutch failure is the drivers fault not the mfg or the car
Clutch failure is not always the driver's fault. There is a know problem with many of thhe release levers on many 996's along with the slave, both of which have been redesigned. A bad lever or worn release bearing canl cause the pressure plate not to release fully and cause excessive disc wear.
you really should do you home work
Vehicle Type: 911 Carrera (996)/911 Carrera 4 (996)
Model Year: As of 1999 (X)
Concern: Creaking noise coming from clutch bell housing area.
Information: When the clutch is activated, creaking noises can occur in the area of the clutch release collar. The
clutch release lever has been modified to eliminate the noise. In the event of a complaint, the release
lever along with the other listed parts must be replaced. The modified release lever was installed in
production on April 19, 2000 from the following transmission number: G9600 1018220.
When installing the new release arm, follow the following points:
l The existing installed adapter, part number, 012 141 751 A, is no longer necessary.
l Insert the sealing ring into the ball journal recess on the release lever and fasten with the retaining
spring.
l Do not grease the ball journal or the ball journal recess.
l Coat the guide tube on the sliding surface of the release bearing with the paste “Optimol MPO”.
l Grease the contact point between the release bearing and the release lever with the grease “Olista
Longtime 3EP”.
Parts Information: Part Number Description
996 116 712 04 Release lever (modified)
996 116 716 02 Ball journal
996 116 741 00 Retaining spring (clip)
996 116 743 00 Sealing ring
000 043 205 10 Optimol MPO (enough to many vehicles)
000 043 024 00 Olista Longtime 3EP (enough to do many vehicles)
Working Time: Labor Operation Time Units Description
34 35 19 00 330 TU Removing/Installing transmission (Carrera)
34 35 19 00 370 TU Removing/Installing transmission (Carrera 4)
30 45 19 50 20 TU Removing/Installing release bearing
Includes: removing/Installing release lever and ball journal.
Reference: 911 Carrera Technical Manual, Group 3:
Repairs: 30 50 37 – Dissembling/assembling clutch.
Technical Information – No. 2/00 – Clutch pedal noises
Technical Information 911 (996)
7/00 3 3041
Creaking Noise In Clutch Bell Housing Area
©2006 Porsche Cars North America, Inc. AfterSales Date: 1-20-06
Page 1 of 2
Binder - 3, Manual Transmission
This bulletin replaces bulletin, Group 3,
#7/00, dated 12-22-00.
the lever was changed due to noises not for cluch release problems,
I have never seen or heard of a bad release lever, thats kind of like having a bad nickle a piece of metal doesnt go bad. funny how your the only one who knows of this problem and no one in the dealership has ever heard of this.
spring.
Longtime 3EP”.
7/00 3 3041
Page 1 of 2
spring.
Longtime 3EP”.
7/00 3 3041
Page 1 of 2
What is causing the noise? The noise is coming from the piston slipping out of position from the lever contact, changing the point of contact and the throw on the lever. This is exactly why they modified the new lever and made a substantial increase in the recess, trying to eliminate this movement. With the piston out of position, the lever does not release fully and the clutch slips. This is more evident when shifting quickly at high engine speeds and lasts for as long as a few seconds before the piston slips back into proper position in the release lever. Many of us have had a new clutch installed without the new lever only to have it slip immediatley. Replacement of the lever corrected the problem.
So, I guess you do not believe that a binding release bearing cannot cause the disc to slip? So, what WOULD happen if the bearing did not release as quickly as designed? Any ideas? This has been a common problem in manual transmission for decades.
Do you actually think that Porsche would issue a TSB stating that the lever will cause clutch failure and have to absorb the cost for a new clutch?
Educating yourself from manuals is a good start, but there is no substitute for experience.
You're a funny guy, Brad.
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
So I guess since you have never seen it, it does not happen? Have you ever looked at the lever? Do you know what makes it slip and bind with the slave piston? Problem exists even with the second release lever issued and they have redesigned the slave to correct it.
You're a funny guy, Brad.![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
EXPERIENCE HAHAHAHAHAHAHAAH
your experience comes from where? your experience with one car (your own)
and what you read, we service 140+ cars a week and no one has heard of your "issue" its funny how some things becomes a "common" issue by one guy spouting off useless information and everybody reading about it.
So lets here it whats your experince, how long have you worked as an engineer for porsche?
(Couldn't resist, just trying to relieve the tension!)
(Sorry, couldn't resist etc.....)
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
