CDR 23 with Bose MOST system going nuts
My radio is having a nervous breakdown. The symptoms are sporadic but this is what it's doing:
-Radio is on, but no sound comes out at all. This was yesterday first thing in the morning; I thought it was the cold that caused it (-2 c). Worked fine 1/2 hour later after a restart.
-Start up the car and sometimes the radio is blarringly loud when it wasn't left like that the night before.
-Sometimes it forgets all the audio presets.
I know that the radio and amp were replaced before under warranty by the PO. As luck would have it, it's going to the dealership tomorrow for an RMS repair (under warranty) so I'll have them deal with this too.
Phil, I had the exact same problem with my radio several months back. Computer showed CD changer fault. The dealer replaced the radio which didn't fix the problem. When they replaced the CD changer, bingo - totally fine. If you're under warrantee, shouldn't be a problem! I got a brand new radio and changer out of the deal - all parts/labor covered under warrantee.
Phil
Phil
My radio also appears to go silent periodically. I've found that switching it to CD mode and then back to FM seems to clear the problem. I don't have a CD changer by the way.
Just wanted to chime in that my Bose system does this too, and they've already replaced one unit under warranty - that didn't help. But I think they only changed the radio, not the amplifier in the luggage compartment.
The regular way to get it working again is:
Change to CD when the system resets itself and starts again
The radio can then be heard, but you can't change the volume and it just says PORSCHE on the screen.
Turn off the radio, and turn it on again -> Working radio.
The irritating thing is it's cold here half of the year... If changing both units has solved this problem for good for any of you, I'd love to hear about it.
Had the same issue with my Cayenne. Same deal - replace radio then replace amp, rince and repeat. Still have issues once in a while (radio seems to "reset"). I have been told that Porsche builds cars not radios!
Not aggravating enough for me to persist. A friend of mine did raise hell though and got dealer to install a satellite radio for free.
Good luck.
Good luck.
Update: the dealer did not change the radio or the amp. The damn thing was working fine when I brought it in. I also learned that the dealer was being charged back over $40K for radios that they'd replaced under warranty and that PCNA was now disallowing. I guess I'd be gunshy about replacing anything with that kind of support from corporate! But thanks for the tips on rebooting the CDR23.
The radio headunit is not made by Bose, it is made by Becker. The speakers and amplifier are Bose.
I still think Bose sucks though, just wanted to clear that up. Oh one other thing Becker is essentially Harmon Kardon, part of the Harmon Group. I've never had much luck with their receivers either and customer service blows.
