Kenisis wheel question
will These wheels work for a 996 with out any complications?
Thanks in advance.
Kinesis K19R
front are 19x10 (I may have said 10.5) with 64mm positive offset
rear are 19x12 with 38mm positive offset
standard Porsche bolt pattern
Thanks in advance.
Kinesis K19R
Ironman 140.6
http://www.1010tires.com/WheelOffsetCalculator.asp
By my calculations you will have the following:
Fronts:
Inner Clearance: -39 mm (the inside of the wheel to the strut housing)
Outer Position: +11 mm (position of the outside edge of the wheel)
Rears:
Inner Clearance: + 2 (the inside of the wheel to the strut housing)
Outer Position: + 52 (position of the outside edge of the wheel)
That will not work on a NB (not sure about a WB).
Fronts:
Rears:
Ironman 140.6
I would not recommend 19's. They are heavier and more expensive.
However, if you want the 19" look, I'd pick something along the following lines.
Front 8" or 8.5" x 19" ET "around" 40 to 50
Rear 10" or 11" x 19" ET 65
Call Wheel Enhancement to confirm fit prior to purchase.
