996 Forum 1999-2005
Winter prep question
Old Nov 29, 2006 | 12:56 AM
Tom911FL's Avatar
Tom911FL
8th Gear
Default Winter prep question
After 14 great years in Florida I am now returning to Scandinavia where I am from. I will be bringing my 2000 C2 with me. I have been in the sun so long that I totally have forgotten what special prep I need to do for winter driving. I am using 0-40 Mobil one oil. I assume that will work well in cooler temperatures? What else should I get done? Appreciate any advice. Tom.
Old Nov 29, 2006 | 01:58 AM
cdodkin's Avatar
cdodkin
Check the mix of the coolant/antifreeze, make sure it's rated to the lowest temp you expect to see, and the mix ratio with water is correct.
A small float tool from pepboys for $5 will do the job.
Get your battery tested - cold will kill an old battery very quickly
Change the mix of your window wash to a higher concentration of washer fluid to water so it doesn't freeze on a cold screen
0W40 will be fine for oil
Hope that helps!
Chris.
Old Nov 29, 2006 | 02:29 AM
MagnusB's Avatar
MagnusB
And winter tires of course.
Old Nov 29, 2006 | 10:42 AM
heelix's Avatar
heelix
cdodkin nailed it. I'll second the battery check - as temps take a dive here in Minnesota, I swapped out the original battery in my 2001 C4. Be sure you have your radio code first (grin).
Winter tires, low temp windshield fluid, and worth checking the antifreeze since you have been in FL all this time.
