Tire size revisited - 285/30/18
I think you summed it up pretty accurately in your other post. Rear will stick out a bit more, but will likely clear the fender without issue (spacers would only make this worse), front will be set under the car by 7mm, so you would need a 7mm spacer to bring it back to stock position.
