Rain Water being dumped
on my rear driver side seat... Don't know where it comes from. Does it have anything to do with the sunroof? Is there a drain that goes down to that area? Any advise on where to look for the problem would be great....the season is just starting
Water drainage plan - Coupe
1 - Water drainage: sliding roof, rear
2 - Water drainage: sliding roof, front
3 - Water drainage: tank tray
4 - Water drainage: evaporator of heating and air-conditioning system
5 - Water drainage: radiator tank
thanks for the drawing...helps! so, i guess i will have to loosen the headliner starting at the sunroof...uughhh....hope i get it placed back in :-(
Originally Posted by 99firehawk
BUT IF THE LINE IS OFFOR ITS PLUGGED AT THE OPENING YOU WILL JUST BLOW THE HOSES OFF THE FRAME
I guess if you're stupid enough to pressurize the lines with an ungodly amount of air, you would be right. However, a blockage that is stronger than the connection of the drain line would be extremely unlikely, if not almost impossible. The connection is almost impossible to disconnect deliberately. Even blowing into the lines with 5 psi is often more than what is necessary to clear them and is an easier job than getting to it from the top. You can also use suction, which is what I do.
o.k....got the drawing...been under the car...where do the lines come out? cannot find them! please one more hint :-) t.y.
btw....cleaned out my garage and found joe schmoo in there....any bids? ;-)
