All you M030 owners
Originally Posted by nycebo
Thought I would add a little more detail (the colors to look for on cab M030 parts) to Dell's solid post (seriously, you are one fast dude, Dell! )
Porsche RoW M030 sport suspension kit:
Total kit = #000-044-500-15 but ensure new front bumptstops
Springs (#996.343.531.12 504 Front green+red, #996.333.531.12 504 or #996.333.531.40 504 Rear green+red depending on VIN)
Shocks (#996.343.041.16 Front green, #996.333.051.13 Rear green)
Bumpstops (#996.343.301.02 Front, 996.333.105.03 Rear)
Stabilizer bars (#996.343.701.21 Front, #996.333.701.13 Rear)
(Reminder: PSM steering angle sensor must be checked and re-calibrated with suspension changes)
Bill
Originally Posted by wrljet
Gert tells me his P96 Euro Sport Suspension Package does not include bump stops.
The Pano article lists different bumpstops for the rear, however. Standard 996.333.105.02 (66.5mm), and Sport 996.333.105.03 (53.5). (for all configurations and markets) And from reading the article, these bumpstops are critical to the whole spring package working as a unit.
Bill
Bill
Thanks,
Bill
The article that Kevin listed above from Panorama has it perfectly. I just never combed it together because I have an '00 cab. Click the link above (ah hell, here it is: http://www.pca.org/panorama/sample_article_3.html) and you'll see everything clearly listed for each type of car.
Of course, if Dell hadn't edited his post, you would have coupe data. Then again, it was likely pre-2002 coupe data.
Good point. Call Gert at Carnewal or Jeff at Sunset. Either one can set you up with the right part numbers.
Now my belief is that when the USA PET catalog says "10mm lower" they mean with respect to the ROW normal ride height.
Bill
It's either -10 (RoWM030) or nothing at all (USAStandard or USAM030). USA is nothing at all and RoW is -10 lower. But in all reality it is much more than that as it is -10 R and -20 F. Mine came in at about 15-17 rear and 22-24 front.
I found this over at RennTech for you:
MY02 Coupe -- 2 wheel drive -- 6 speed -- RoW M030 Sport Suspension Parts:
Front
996 343 041 18 -- Shocks
996 343 531 19 -- Coil Spring (set of 2), color coded Green/White
996 343 701 04 -- Stabilizer (swaybar) (23.6 mm)
996 343 511 00 -- 3.0 mm compensation plate
or
996 343 511 01 -- 6.5 mm compensation plate
Rear
996 333 051 22 -- Shocks
996 333 531 26 -- Coil Spring (set of 2), color coded Green/White
996 333 701 17 -- Stabilizer (swaybar) (19.6 mm)
996 333 105 03 -- Additional Spring (bump stop 13 mm shorter than stock)
996 333 511 02 -- 0.5 mm compensation plate
or
996 333 511 03 -- 4.0 mm compensation plate
Front
or
Rear
or
Newbies Hospitality Director
Front
or
Rear
or
Front
or
Rear
or
Compensation plate compenstates for variations between mass produced springs.
The matching plate is used with the correct color coded spring.
26, 333, 701, 996, 99633351103, 99634330102, air, bumpstops, compensation, filter, kit, m030, plate, porsche, row, suspension
