Brake pedal spring noise...can I remove it?
I seem to have a noise coming from a spring on the back side of the brake pedal. This spring looks like it helps bring the brake pedal back up to the top when the brake pedal is released.
My question is, has anyone here had the same problem, and if so, can you just remove the spring? Or will removing the spring cause the brakes to not fully release?
If I can't remove the spring, is there a way to stop the noise other than turning on the radio?
Car is a 6 speed if that makes any difference in the brake pedal... I doubt it. Thanks.
Originally Posted by 99firehawk
what kind of noise and when does its do it when depressing or releasing
