Wheel size question? Will 19x11 rears and 19x8.5 fit 02 narrow?
Hi guys,
I got some wheels on order from iforged and after thinking about the wheel size that i had order, I'm a little worried that the fronts may be too small in width. Are 19x8.5 sufficient enough for the fronts? On my old M3, i had 19x10 rears and 19x9 in the fronts.
Should i go with 19x9 in the fronts?
The differential in widths between fronts and rears is 2"-3" for factory wheels (7's and 9's or 8's and 10's on narrowbody 996's and 8's and 11's I think on GT3's), so no, you don't need to go to a 9" front. You M3 has the engine in the front, your 996 doesn't. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
If you post the offsets on these wheels you can get an answer as to whether they fit or not.
First 8.5/11.0 are the stock widths for a GT3. Keep in mind these are very rear end heavy cars and will have a lot more rubber out back versus a car like an M3 with a more even balance. I run a custom set of CCW 3-piece 18x9.0" fronts with 235/40's and 18x11.0" rears with 295/30's for race wheels with no problems. You can go with a 8.5" front wheel, but since you are having the wheels made I would suggest ordering the 9.0".
02 carrera, well if the stock widths for a gt3 are 8.5/11, then i think it would be safe to say that that's an ideal tire width for my car, correct? Plus i think it's kinda too late to change the order. I placed them about 2 1/2 weeks ago. They should be ready by the end of this month.
I ordered the Precision series essen in race gold. My car is a lapis blue, what do you guys think? I decided on the race gold cause silver is too plain, and black is ok with me, but race gold is unique and different. Here's a photoshopped pick of what it might look like. OF course the pick is of a turbo with techart front and turbo wing. I'm thinking about going the same route (tech front, either misha gt2 wing or turbo wing).
![](http://img175.imageshack.us/img175/8/blueandgoldjs0.th.jpg)
