AAGH! CEL back after 90 miles!
#31
Originally Posted by 99firehawk
few years of working on them, ive replaced probaly 4 o2 sensors and 50 cats
#32
When I had both cats replaced on my 02 the dealer indicated that he had replaced the cats on 2 other cars in the not too distant past. That's 6 cats.
It may be that there was a bad supply of substrate for the cats. If one considers that the metal substrate is rolled to 0.0015", thinner than your hair, then a 10,000 lb. master coil would yield a lot of cats. Fecralloy and Apha-4 used to be common substrates for cats and both are difficult to make at best. I've been away from those products for a while so I'm not sure if they are still the prime candidates.
Either of those alloys will withstand 1000C, 1832F, with no problems. To get beyond that temp the cat would have to be subjected to an overly rich condition. The typical failure mode for a metal cat would be small shards of metal separating from the monolith and exiting with the exhaust. However, if you have two cats in tandem the downstream cat might get plugged by an upstream failure. That is what you don't want to happen as you would get increased back pressure on the engine. A good reason not to ignore a CEL.
#33
Originally Posted by 1999Porsche911
We are talkiing 996 CAT's here, not other cars. Are you trying to tell us that you have replaced 50 996 CAT's? I find that hard to believe since they are an emission warranty item that would be replaced free by the dealer.
all but maybe 2-3 fell under 8yr/80k and were replaced by dealer
#34
#36
Lead Rennlist
Technical Advisor
Lifetime Member
Lead Rennlist
Technical Advisor
Lifetime Member
Ciao,
Adrian.
