Service wants to replace rotors with each pad change?
Just took my 996 in for it's 48K km service and they called me to advise a front pad change. They also told me they wanted to put in new rotors so the pads bed properly? WTF? Is this common practice or is this a cash grab at $1000? Rotors are not cracked or warped. Anyone with any insight?
Just change the pads if the discs are not cracked or warped and break the new pads in properly.
Take the car out and get to an area where you can accelerate and brake repeatedly. Get the car up to 50 or so and then evenly apply the brakes until almost stopped. DO NOT keep you foot on the brake pedal when you are stopped (unless you HAVE to). Repeat several times, inceasing the pressure you apply to the brake pedal. A couple of hard braking applications will complete the break in. Now enjoy the car.
You can also drive the car while applying the barkes lightly while driving. Keep doing this for several miles increasing the pressure to the pedal. The idea is to get the brakes hot and seated without letting the pads sit still against the rotor. No further break in is necessary.
Lead Rennlist
Technical Advisor
Lifetime Member
Lead Rennlist
Technical Advisor
Lifetime Member
Ciao,
Adrian.
Service advisor made no mention of the width of the rotor, he said it was common practice to change the rotor out with each pad change...
You can always wait for the brake wear sensors to tell you that the brakes need replacing.
I would wait too till the light came on but the dealer should call you and tell you they may be close to that point. with a 15k mile service interval the warning lamp may come on in 5k miles and the customer may come in and throw a fit becuase " I was just here for a maitanence and you guys didnt notice my brakes were worn"
Even if they do need changing, it's an easy DIY that will cost you lots less. I just had my 48K done and neither pads or rotors needed replacement. When my pads (and or rotors) do go, I'll do it myself.
BTW: which dealer, Pfaff or DFC?
Chandler!
Front rotors and pads are $330 for the set.
I've been driving a 996 since early 2001, and every time I bring my car in for the major service they want to change my rotors, I'd be $6,000 in the hole if I did that.
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
Lead Rennlist
Technical Advisor
Lifetime Member
Lead Rennlist
Technical Advisor
Lifetime Member
Their reasoning is not correct. I would go down there and take a look for yourself. You said you asked for the pads to be replaced, why? Are the rotors scored?
The mileage is irrelevant it's how the brakes have been used in the posted mileage that counts. You do not need to track a Porsche to wear out the brakes quickly.
Based on your posts the argument from the dealer is not sustainable. Pictures might help.
Ciao,
Adrian.
It was DTFC. I'll take pictures of the rotors when I get the car back this afternoon. I asked for the pads to be changed because they said I was 1mm away from the pad sensor. The whole experience has left a sour taste in my mouth with this dealer's service.
Chandler!
Lead Rennlist
Technical Advisor
Lifetime Member
Lead Rennlist
Technical Advisor
Lifetime Member
Have they changed the rotors?
Ciao,
Adrian.
Necessary or not, changing rotors seems like the norm these days. In years gone by it used to be that rotors would be turned more or less as a matter of course when changing pads even if that wasn't needed. These days rotors for most cars are cheap enough that it's generally not worth the effort as cast iron is a bugger to work with and the tool gets dull after a rotor or two so the new money spinner is new rotors. That logic doesn't necessarily apply with Porsche prices of course but the same mentality seems to prevail.
Colin
Colin
