Do I have an Oil Pressure issue?
Originally Posted by s14roller
I was actually seaching the same topics yesterday. Most people run around 4-5bar at 3000RPM+. Mine is at 4-5 bar pretty much anytime the car is driving. It idles at the light ~ 2.5 bar.
Originally Posted by LiveFromNY
Yeah, it is. Don't have my manual handy but pretty sure the manual shows pressure below 1.5 at idle when warm...
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
Originally Posted by Alan C.
Mine runs the same as 1999Porsche911's. Did you recently change oil?
It never made it to full temp before I hit the gym. After leaving, get back in car and it tops out at 3.5 at idle???? Its acting normal after everything gets warmed up, but the 4.5+ is not what I have been experiencing. Could the start of colder weather in the past couple of days cause this? Cincinnati AM temps have been low 50's? Just want to make sure I am not driving and causing an issue! Thanks
Queens city - it sounds like your car isnt fully warmed up, so your 3.5 at idle on a cold car sounds right. Remember as oil warms it becomes less viscous (and there are 9.25 qts of oil in the m96 engine).
I posted a similair question a few weeks ago, I was getting ~3.5 >4K RPM, and 1-1.25 bar at idle. While not uncommon, the answer seems to be from the weight of the oil... 0w40 just seems to get to thin for these engines. I am running 15w50 now, and I get 1.5 when car is HOT at idle, and >4 bar when >~4K RPM.
I have a feeling that you are going to see dealers go back to 15w50, the original factory fill...0w40w is too thin for these engines.
Originally Posted by QueenCityCarrera4
I had the whole car gone over after I picked it up in St. Louis, this included an oil change with the "water" oil. I have done nothing since. I watched it again this AM, as soon as I start it up, it goes to 4.5+ and stays there whether I am driving or idling. Sounds like others have it the same, but for me, it has NEVER registered this way.
It never made it to full temp before I hit the gym. After leaving, get back in car and it tops out at 3.5 at idle???? Its acting normal after everything gets warmed up, but the 4.5+ is not what I have been experiencing. Could the start of colder weather in the past couple of days cause this? Cincinnati AM temps have been low 50's? Just want to make sure I am not driving and causing an issue! Thanks![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
I did check my oil level and its right on the money. The car is a 2001. It is going to 3.5 + at 4k RPM or cruising speed, so all is still good there. I am thinking since the "problem" just started and the weather just started to turn, that that is the cause. Its just that I have never seen it go to 4.5+ at startup and stay there whether cruising or idling until warm. I just dont want to screw the darn thing up. Could it be the gauge is starting to go bad???
Whats actually happening now, as opposed to all of the other days in the first 4 months, is that it is 4.5+ at speed AND idle. It has never done that, it would at least drop down a bit at idle. It now stays at 4.5+. It does go to 1.5 at idle like it used to when warm.
Regardless of the ambient temperature, once the engine is warmed up, the pressure guidlines I stated earlier still apply. If you are getting a change in reading, I would first look at the oil sending unit. You may have a bad ground or need a new unit. They do go bad at times and it is not a big deal to replace. Not having pressure above 4 bar when cruising above 3000 rpm is unlikely mechanically, so sending unit or gauge would be my guess.
Originally Posted by Tippy
mine in south texas on a 100+ degree day gets as low as 0.8 bar at idle with 15W-50 weight mobil one
In tests that I have conducted in 103F temps using 15W50, I was unable to get the oil pressure below 1.3 bar (using a calibrated, inline pressure gauge). This was even letting the engine temp get to 230F and idle of 800. Removing 1 quart of oil from the engine made the pressure drop by .3 bar in same conditions. Those with idle below 800 will experience slighty less pressure.
Thicker oil will indeed give you a higher oil pressure reading but the normalized flow (hot) should not change, just the pressure that is generated from pumping it! Motor protection is dependant on the volume of oil pumped to the surfaces which are cooled and lubricated by that volume, not pressure...if you feel better seeing a higher oil pressure on your gauge, thats OK, just be aware that pressure is no indictation of an oil doing any better at protecting things. Lubrication protection is determined by volume, not pressure.
![Exclamation](https://rennlist.com/forums/images/icons/icon4.gif)
That's exactly what my mech. says with the miles I have I need oil flow not pressure and he recommended 5w30 and I never have a problem. fwiw he's owned and worked or these cars since 74.
