White smoke on start up
Started my car yesterday(cold start) and white smoke came out the exhaust.
Has never happened before. It didnt happen this morning, but it has me concerned.
Anyone have an idea what causes this?
Ironman 140.6
A little smoke on start up is normal for a "flat" motor. Oil can accumulate in the cylinder walls rather than drain (since the cylinders are horizontal). This oil will burn off when you first start the car which will cause some brief smoke.
My cars only do it occasionally, but it does happen. It is a fairly common question on the board.
Originally Posted by vegascomedy
Definately white smoke. Will see if it happens again.
Thanks for the replies!
Same here, usually happens at startup afer the last hard run.
Then it goes away at the next startup (or next few days) after driving it for a while without pushing hard.
In fact, I notice mine has more smoke come out of the passenger side exhaust than the driver's side.
Wonder why...?
Wonder why...?
Newbies Hospitality Director
Originally Posted by BruceP
I think it means your car has elected a new pope. Not sure, but I think that's what it means.
Hope that's helpful.
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
If I start the car and run it for a very short time, then park it overnight, I get white smoke when I start it the next time. This usually happens if I pull the car out of the garage, wash it, and put it back in. On the other hand if I drive the car around the block after washing and drying it (to blow the water out of the crevices) then there's no white smoke the next day.
Michael,
I wouldnt be to concerned as it does occur, for me its when she sits in my garage for over 4 days. Usually on start up it occurs then next day it will be fine.
Ironman 140.6
In reality the white smoke on start-up is largely ceremonial. Every 911 does this from time to time to celebrate the year that it took to produce them.
Riad gave a good description of the process.
Originally Posted by riad
As far as I know they are made by hand on a small mountain top in Germany. After each one is built they ring a giant bell on top of the mountain and pull it down by donkey to the local village where they celebrate all through the night with dance, song and plenty o' stein filled with hops.
After the festivities a local priest blesses each one on its journey to it's new home, and it's loaded into a giant sheepskin lined case and sent to America for a new start.
I believe this whole process takes about a year for each car... I'm trying to verify this.
