996 Forum 1999-2005
Airbrush paint chips
Old Aug 31, 2006 | 03:17 PM
evansaero's Avatar
evansaero
Default Airbrush paint chips
Has anyone else tried this?
I spent all yesterday trying different methods. I tried the toothpick, paint brush from the sample paint, paint brush from art store that I cut down.
None of these worked well, at least not for me.
I went to the hobby store and bought an airbrush kit for $30 it came with everything I needed, I figured that I would not need the type that runs off a compressor being that I will probably only use it a couple times a year. It comes with a can of compresses air and if you run out you can hook it up to your tire and use the air from that.
It works well for me and I will have to write a how-to with pictures after I get a little more practice with it.
I found that I get an even layer with no bumps in it; also it works well for really big chips.
Old Aug 31, 2006 | 03:25 PM
LiveFromNY's Avatar
LiveFromNY
None of these worked well, at least not for me. I spent last night lying in bed and had an idea that airbrush would be the way to go.
Some detail shops will do airbrush paint chip repair and I've had good luck with it in the past. I saw more of it when I lived in CA. Seems to be less prevalent here on the east coast.
