996 Forum 1999-2005
Final Detail
Old Aug 23, 2006 | 11:37 PM
evansaero's Avatar
evansaero
Default Final Detail
Today is a new day.
The paint got a do-over.
7 hours
1.Wash
2.Clay
3.Wetsand scratches (Step 1. 1500 grit Step 2. 2500 grit Step 3. 3m scratch remover)
4.Polish (Deep Crystal System Polish)
5.Glaze (No.7 Show Car Glaze)
6.Wax (NXT)
Now it's time for that beer
Tomorrow I take a road trip up to Skyline Drive
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old Aug 24, 2006 | 02:57 AM
Mitty's Avatar
Mitty
Nicely done, sure looks purrty!
Old Aug 24, 2006 | 07:31 AM
gota911's Avatar
gota911
Newbies Hospitality Director
Aaron - WOW you car looks AWESOME. Great job! I did the same (minus the wet sanding) two weekends ago. It is amazing that even with careful hand washing you still bet a few fine scratches in the paint.
Old Aug 24, 2006 | 07:40 AM
washington dc porsche's Avatar
Wetsand, how do you do that?
Old Aug 24, 2006 | 08:32 AM
Steven C.'s Avatar
Steven C.
Wet sanding is for deep scratches that polish wil not remove. You are basically lowering the clear coat around the scratch to the depth of the scratch. BE CAREFUL NOT TO SAND TOO DEEP INTO THE COLOR BASE COAT! The base coat is designed to have the clear protective coat over it. Just take the gits of sandpaper listed above and a spray bottle of water and first thoroughly soak the paper. Then spray the surface generously while sanding in straight motions over the scratch. If the area is flat a small block of rubber can be used to wrap the paper around. If it is curved (which most surfaces on our cars are) then just use your fingers. Sand as small an area around the scratch as needed. After the 2500 grit the scratches left by the sandpaper are so small that a polish will remove them. And wala No more scratch!
The same process is used for lowering the touch up paint used to fill a rock chip.
Old Aug 24, 2006 | 11:36 AM
Chaos's Avatar
Chaos
My friend painted the rear bumpers,looks great !
