Michelin Pilot sport N2
They are non directional. However there is an outer sidewall and an inner sidewall. The tire can be mounted on either side of the car, and rotated from side to side.
Chandler!
Originally Posted by LVDell
I thought it said "rotation"
Hi, they are on some GT3 wheels I bought. The outsides are cool but I guess they are not directional. I took off the stock wheels and Bridgestones and the rears are pretty worn. The thing I noticed was right rear was worn more than left side. In a car with the traction of the C4S I was surprised? I need the UPS guy to get here with my 17mm spacers. Then when my wife comes home she might not notice ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Steve
Steve
Pilot Sport are directional.......no doubt.
PS2s I believe also are.........s/be an 'inside'...'outside' designation........AND looking at tread, see how tread on one side is dif than other.......see how water would be channeled away with one direction of rotation......not the other.
Steve, my last link was for a PS Rib, but IIRC the GT3 tire is a PS2. Here is the pic of the PS2. You can clearly see the work "outside".
Michelin PS2
Michelin PS2
Yup, that how they are mounted but there are no directional marks so at least I can rotate side to side and keep them on longer. The tires came mounted from a Rennlist memeber, you may remember all my questions about rear offset etc. I tried the rear on but with 63 offset they rubbed inner fender just barely. FYI
Front says 91Y N2
Rear says 98Y N2
"Outside" is clearly marked. The tires are barely used but may be older. Does N2 mean OEM/factory?
Steve
Front says 91Y N2
Rear says 98Y N2
Steve
Steve
Steve
Chandler!
Originally Posted by GreggT
I wouldn't........but suit yourself.
Do you mean that once mounted you wouldn't switch sides? If so, why?
