SNOW TIRES
SNOW TIRES
I know many are not thinking about this yet, but are the dunlop M2 still available? Didn't see them at tirerack in 255/40/17. I still have two good front ones.
I was doing a pre-emptive winter tire search...found nothing on tirerack .
There is a guy selling a used set on Ebay in the Chicago area...if that helps.
thanks,
Amir
thanks,
Amir
I use Dunlop Wintersport M2's on my wife's car. I had to replace two last year. According to Tirerack last year the M2 had been discontinued and was beening replaced with the M3. Since I could not get the M2's I utilized two M2's and two M3's last winter with no problem. According to Tirerack mixing the M2 and M3 is not a problem because of the similar construction and grip levels, they just recommended having the axles the same.
Originally Posted by rcg412
is there much difference between the M2s and M3s? I use M2s now...
