Woofer Box (Lots of Pics)
Another thread wanted pics of recently installed woofer boxes, and I've been meaning to post mine, so here they are.
The woofer box is custom built by Rod Birch at CarAudioInnovations. Note the flush fit in the car, and the extra matching Porshe carpet to make to box install look seamless and SWEET! He has different options for the speakers, but I elected for the 3 JL subs run by an Audison amp. With my Focal speakers all around, this system is the best sounding car audio I've ever encountered (patting self on back, lol).
[If you look close, you can see where I need to tuck the carpet into the very rear panel so that the rear vents aren't covered.]
Outside of Car Pics
Inside Pics
Carpet untucked
Box Turned Upside Down
Outside of Car Pics
![](http://td873.enteronline.net/Car1/woofer/outside1.jpg)
![](http://td873.enteronline.net/Car1/woofer/outside3.jpg)
![](http://td873.enteronline.net/Car1/woofer/outside2.jpg)
![](http://td873.enteronline.net/Car1/woofer/outside4.jpg)
![](http://td873.enteronline.net/Car1/woofer/outside5.jpg)
Inside Pics
![](http://td873.enteronline.net/Car1/woofer/inside1.jpg)
Carpet untucked
![](http://td873.enteronline.net/Car1/woofer/inside2.jpg)
![](http://td873.enteronline.net/Car1/woofer/box1.jpg)
![](http://td873.enteronline.net/Car1/woofer/box2.jpg)
wow, very nice....thanks for the pix!
Yeah, I was considering going with Rod's 3 JLW6 box at first, esp after I tried to hack the blose box and pretty much failed with some 6's I had lying around.
However, when I stuck a 1-10 enclosure back there just to get me thru, I really became attached to the extension of the 10. Now being that there are 3 6's wired what I would imagine is in parallel, I have a couple of questions:
1) what is the ohm rating that the amp sees?
2) how would you compare the extension and response to that of a 1-10? And this is given that with a 3-6 setup, you're moving a tad more air..
TIA
TIA
The setup looks great!
I am curious though, seeing that the enclosure was properly made (MDF),
how much total weight did you add to your car in the back?
Is it close to 60-70 pounds or more?
-td
TIA![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
TIA
As far as extension and response -> the response is much better than one 10, but the base isn't quite as deep, IMO. (I had one 10" in my old Camaro). But since I listen to more rock than rap, the tightness is more important to me. Rod has other setups with more/bigger speakers, but I'm really happy with this one! (These are 6.5" speakers, so having 3 running is like having a 10" and a 5" woofer, FWIW).
cool... Yeah, I'm more Rock/Jazz/Techno/Lounge myself (in that order) so the kick drum/thump is what I look for, not the richter measured boom...
This was very helpful - thanks for the info!
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
Newbies Hospitality Director
When I read the thread title, I thought it was going to be pics of an ugly girl's private parts! Thank goodness it was just part of an audio system! ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
BTW, nice job.... but can you even hear the engine or exhaust notes with that in the car?
Great pics, td. Your install is different than others I've seen. It's nice to see another option. It has actually given me a couple of ideas to alter what I was originally planning on doing. I'll try to take some pics as it unfolds to share.
you can actually buy this box straight from Car Audio Innovations (whom many on this board have worked with) finished with carpet and everything. They also have a few others that are a bit more $, but seem to pack a lot of punch.
Therefore, assuming you have the amp and wiring in place, it would simply be a bolt in procedure, which should just take a few minutes. Otherwise, you're looking at amp and wire install from any local car audio shop.
Originally Posted by s14roller
How much would a custom box like this cost with installation?
The front speakers also need extra wiring since the stock speakers only have one pair of wires and the components need 2 sets. There are also a few odds and ends (i.e., adapters) needed for the install. I had the amp mounted in a false floor in the trunk, and mounted the cross overs where the factory amp was.
Installing just the amp is a breeze - simply plug and play (it was prewired).
To get the whole thing done at a car stereo store will take between 8-16 hours depending on what needs to get done (like building a fake floor or mounting your speakers in the grills). The whole install will cost somewhere in the neighborhood of $600-800.
If you are handy, and have time, I think the self install (after getting the speakers mounted) would be a great DIY.
-td
