Limited Slip Differentials
Originally Posted by SleepRM3
Electronic aids help inexperienced drivers, but hinder experienced drivers. With my student's '99 996, PSM would have kept him out of the weeds, but I would not have had as much fun rotating the back end of his car at full speed LOL I noticed the 2000 996es had LSD as optional but also have traction control as standard? The 2000 sounds like a winner?!
To my knowledge, the 2000's did not have the LSD option. The 1999 had it with TC which could and should be turned off perminently. Secondly, teaching people to drive with all the "sissy" controls (IMO and experience) is not the best approach. So much of succesfull driving involves the FEAR factor and giving a student a crutch while learning quite often instills too much confindance and allows them to achive maximum handling out of the car with a parachute. However, this has done little to teach them how to control a car properly. The "sissy" controls also kick in too soon compared to the actual ability of the car to safely navgate certain corners.
We use to teach people to drive in a car with no camber and artificially light in one end. This allowed the student to actually learn how to control a car that experiences unpredictable things. After experience in driving a car like that, they could get into a properly setup car and have a little more respect for what it could and couldn't do and how to safely adjust when the car hit it's limit.
However, for those that simply want to get around the track quickly without even knowing how to drive, then the "sissy" controls come in handy.
In looking through Edmunds.com, they list LSD as an available option for the 1999 and 2000 911s--but the LSD option disappears from the options list from 2001 to 2005. The list of options are shown when you go through the "customized appraisal" worksheet.
If what you say is correct about model year 2000 996es not having LSD as an option, then I'm limited to the 1999 996. While the market asking prices for the '99 911s are within financial reach of most enthusiasts, I'd say we're a bit intimidated by first-year production run glitches as is the case with most car models--even Porsche 911s--I suppose?!
I've read in Excellence magazine that early 996es (and 986es) were plagued by oil leaks--most were caused by a faulty main seal--while others were caused by porous crank cases (the oil actually leaches out through the metal). Most should have been replaced under warranty by now??
The 40th Anniversary cars made in '04 have limited slip.
Now this 1999 996 is more of what I'm looking for.
http://cgi.ebay.com/ebaymotors/1999-...QQcmdZViewItem
St Louis MO isn't too far to drive to check this car out. They posted an options sticker showing number 220--isn't that the option code for limited slip differential? Also how do I know if this car has a bonafide throttle cable, or electronic throttle?
Sleep,
that looks like a very fair price for a low mileage 99 with good options. Provided it checks out. Just bought one too so I have bunch of the codes handy. This car has 3 spoke steering wheel, LSD, TC and ABD, Xenons, Hi Fi sound, Painted crests, Oval Chrome exhaust tips, Heated seats, etc.
Similarly, I just sold my Black/Black 1997 M3/4dr. Will miss that car all around.
Best of luck!
-paul
Best of luck!
-paul
All the 1999 C2's had the cable. The 1999 C4 was egas.
Originally Posted by pjalexandre
Sleep,
Best of luck!
-paul
Best of luck!
-paul
I'm not quite ready to pull the trigger this soon--frankly I thought it would take longer than a night to find the right car--but you're right this car looks cherry--I especially like the LSD/TC/ABD, Arctic Silver paint, clear turn signals, and 18-inch wheels.
I'm afraid of oil leaks with a Porsche--my bimmer's tight--it holds all its fluids .
I hear ya, but all high-end cars need TLC. The M3 was mostly bulletproof but there were little gremlins like the plastic water pump impellers, plastic radiator, rear shock mounts. etc. 996's have RMS and if it happens is $800K. Get a warranty for around $2k or just be prepared to shell out some cash if something substantial goes. My M3 surprised me one day with a blown AC that cost just over $2K to fix, not under warranty anymore.
There are some guys on here with cars over 100K and counting. Cars that surely at driven hard and often. If you snoop around here will find the guy(s) with blown motors, bad trannies, etc. But there was the same type of stuff on the e36 and e46 boards. I am happy with the move to the 996. Much more of a pure Sports car over the very practical and very good M3.
A little more than 2cents that time
$230 of that was the special tool...It just takes a little bit of time and patience. Look at it as paying yourself $120/hr to do the work!
-Keith
I had a '99 with the LSD/TC (they dropped that option in 2000 when they brought out PSM) that I bought new in April '98 (sold it 2 years ago to get the GT3). Don't believe everything you read, it was a great car. I did lots of problem free DE's and the RMS was replaced under warranty and never leaked a drop again.
With this many years on them now, it should be easy to sort out the good from the not-so-good. If one was going to have an issue with the dreaded RMS, coolant expansion tank, tranny, etc., it would have done so by now. Don't pass up one that checks out mechanically, meets your needs and is reasonably priced.
Sleeper,
Those guys (Schmitt) are about 10 miles from me. If it comes down to it, I could cruise by and check the car out a bit. I might be able to find the PO as well.
Originally Posted by Russ Murphy
Sleeper,
My wife's been nonchalant about this hunt--she's seen me go through my PorscheQuest before (the last PorscheQuest was for the right 3.2-L Carrera, but I got a BMW 97 M3/4 instead LOL).
BTW, I have to compliment you all. This has been a great board. I've been a registered user for 24 hours, and not once have I seen a negative post.
Thanks for all the help and encouragement in researching these stunning cars.
