Will lights from a RHD drive car fit a LHD car?
I assume they are of the same P/N, but I wanted to check-in with the experts before bidding on them
BTW, They are 99-01 (pre-facelift) litronics...
Thanks guys...
Thanks guys...
Technical Guru
If you come across the -01 litronics again the part numbers you want are #996-631-157-07 and #996-631-158-07. The right-hand drive headlamps are #996-631-157-01 and #996-631-158-01. The other thing to watch out for when buying used is the left-hand drive litronics made for the ROW (#996-631-157-04 & #996-631-158-04) are not the same as USA/CAN models. Good luck with your search!
