996 Forum 1999-2005
BK harness Bar and power seats....HELP!!
Old 05-20-2003, 02:49 PM
Palting
Palting's Avatar
Post
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by Kerry:
<strong>Palting,
What are the B-K part numbers of the equipment you are installing?</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">R1029 - Harness bar for cab. I have the Bose rear sub, so I can't use R1030.
R9001 - Tunnel side belt mount
R9003 - Outside side belt mounts. This is the one with the 2 piece spacer.
With the Schroth 6 point, the sub belts mount to the same point as the side belts. I think that's true for all 6 point belts.
Old 05-20-2003, 05:33 PM
Kerry
Kerry's Avatar
Post
OK, thanks. I thought you must have a different harness bar as I didn't have to fool with seat stops.
About the R9001 tunnel side belt mounts. I wasn't happy with the way the lap and sub belt clip into the opening on the R9001. I felt the opening was much too small, the clips didn't align right and the risk of the clips accidentally un-clipping too great. Maybe that's just me <img border="0" title="" alt="[Wink]" src="wink.gif" /> . I saw what B-K makes for the Corvette; it has two holes, one for each belt. I talked with other people who use the R9001 and they said it's common to enlarge the clip hole so two belt clips can attach and easily move and align. So I had a machine shop mill out the opening so the sides of the opening are now .135" at it's narrowest. I'm happy with how the belts clip in now; the sub belt clip can angle down towards the seat bottom and the lap belt clip can point upwards. I believe this part is still one of the strongest parts of the harness system, even after removing the metal.
Old 05-20-2003, 09:07 PM
Palting
Palting's Avatar
Post
You mean I may have to remove the seats again and mill the opening out? Bummer. The belts are arriving Wednesday. I'll see how they fit.
Old 05-21-2003, 07:12 PM
Palting
Palting's Avatar
Post
Kerry, I see your point. I could barely get the two clamps in on the tunnel side, much less orient them they way I feel they should be. As you said, sub-belt down and lap belt up. 0.135" huh? OK. It's off to the mill shop I go.
Seems like they could easily have designed one with a bigger hoop. Know any one that does have that design?
Thanks.
Old 05-23-2003, 12:39 AM
Kerry
Kerry's Avatar
Post
Sorry I'm so late with this, been out of town.
No, I don't. I had my dealer contact B-K to see if they would make a modified R9001 and they got no response. I had the dealer send a picture of what I'd done; again, no response.
Here's what mine looked like after they will milled out. I was hoping the shop wouldn't make the bottom of the opening thinner than the top, but I think they had to in order for it to fit. Notice the top part of the opening is not milled out, just the bottom.
<img src="http://boards.rennlist.com/upload/RileyBK9001.jpg" alt=" - " />
Old 05-23-2003, 01:57 PM
Patrick
Member - times 3
Patrick's Avatar
Post
You can call BK yourself. They made me a set of modified parts (shorter) for my GT3 seats.
Quick Reply: BK harness Bar and power seats....HELP!!
