996 Forum 1999-2005
GT3 sway bars clunk??
Old 07-08-2003, 08:07 PM
JLJ
Registered User
JLJ's Avatar
Post GT3 sway bars clunk??
got GT3 sway bars, drop links and h & R springs installed today...have a clunking noise over bumps..i understand the drop links are now metal on metal but is this normal?
Old 07-08-2003, 09:12 PM
sharkster
sharkster's Avatar
Post
I have the H&R sways and it's totally normal. Comes withthe territory of having stiffer sways with polyurethane bushing. Take the bumps sideways gangster style or just apply some extra lube under those bushings. But I wouldn't worry.
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by JLJ:
<strong>got GT3 sway bars, drop links and h & R springs installed today...have a clunking noise over bumps..i understand the drop links are now metal on metal but is this normal?</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">
Old 07-08-2003, 10:16 PM
Ed Newman
Ed Newman's Avatar
Post
From my understanding this is NOT normal. The bars are contacting the A-Arms. If you are using coilovers, you need to lower the drop link pickup, or if you are using adjustable drop links, extend the link. A 1/4" should be plenty to have the bar clear. Be careful as contact can result in broken links and this is not something you want to fail around a turn going fast.
Old 07-09-2003, 12:18 PM
JLJ
Registered User
JLJ's Avatar
Post
went back to shop..he said clunk was normal as drop links are metal on metal...alon suggested gert at carnewal might have a solution...any other input?
Old 07-09-2003, 11:47 PM
Ed Newman
Ed Newman's Avatar
Post
IMO, metal to metal contact that goes clunk is never good. I put the Racers Group drop links in my car and there is not clunking
Old 07-10-2003, 12:17 AM
Oak
Oak's Avatar
Post
I also have the GT3 sways with TRG DL's and have absolutely no clunking.
Old 07-10-2003, 02:07 AM
Mike in CA
Mike in CA's Avatar
Post
<strong>got GT3 sway bars, drop links and h & R springs installed today...have a clunking noise over bumps..i understand the drop links are now metal on metal but is this normal?</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">What drop links are you using?
Old 07-10-2003, 09:14 AM
JLJ
Registered User
JLJ's Avatar
Post
metal ones..i dont know brand...gert at carnewal said there is a fix...he also told me that metal drop links are the best but that they are too noisy for the street
Old 07-10-2003, 11:01 AM
Ed Newman
Ed Newman's Avatar
Post
I'd agree that metal droplinks are the best. The paper or plastic ones don't seem to be strong enough. Just kidding. If you did H&R springs only, you have fixed droplink mounting points. Fixed points and an adjustable sway bar really should use an adjustible length droplink to keep the bar in the right place and make it so it does not contact anything. Gert can get you the Porsche parts (big $$$) or call TRG and get theirs.
Old 07-10-2003, 02:17 PM
JLJ
Registered User
JLJ's Avatar
Post
i do have an adhustable drop link..it isnt hitting just noisy...not too bad just not silent like stock
Old 07-10-2003, 03:08 PM
Oak
Oak's Avatar
Post
Look for the teflon lined ball joint design. These should qualm the noise.
Old 07-10-2003, 09:16 PM
ringmeister
ringmeister's Avatar
Post
I have a '04 GT3 and I did experience a "clunk" after driving it for two days on the Nurburgring. Upon ispection I found the front drop links to be loose. Once tightened all was fine and back to normal.
Old 07-10-2003, 09:51 PM
Oak
Oak's Avatar
Post
ringmeister,
good advise, always check the most simple and obvious first.
Old 07-11-2003, 12:08 AM
Ed Newman
Ed Newman's Avatar
Post
Mine links are metal to metal and no clunking. Good idea to check to see if they are loose. Hoe do you know they are not hitting? Did you stick your head under the car while it was driving? Don't try it if you have not!
Old 07-11-2003, 02:06 AM
Oak
Oak's Avatar
Post
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by Ed Newman:
<strong>Hoe do you know they are not hitting? Did you stick your head under the car while it was driving? Don't try it if you have not!</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">LOL!
Quick Reply: GT3 sway bars clunk??
