996 Forum 1999-2005
oil level question
Old May 22, 2006 | 11:45 PM
delirium's Avatar
delirium
Default oil level question
I changed my oil by myself, but I want to check to see if my oil level is ok. This is what I see:
Oil is cold: on electronic meter, all bars are filled.
2 minutes after pulling into garage: on electronic meter, 3 top bars are empty
10 minutes after pulling into garage: on electronic meter, only 2 top bars are empty.
On dipstick, the oil is right below the top (max) notch. The notch itself does not have any oil on it, just right below it on the bar.
So, my oil is a bit on the full side, but is not beyond max (all bars filled) when at operating temps or higher.
Is this acceptable? Should I drain some? (I have a fluid extractor)
Old May 23, 2006 | 12:12 AM
cdodkin's Avatar
cdodkin
You're good to go.
Don't sweat it - you're right on the money.
Chris.
Old May 23, 2006 | 12:35 AM
gota911's Avatar
gota911
Newbies Hospitality Director
Agree with what Chris said above. ^
Old May 23, 2006 | 01:23 AM
10 GT3's Avatar
10 GT3
There is nothing unusual here. Keep in mind when you run the engine, oil is cycling through it. When you turn it off, it takes time for the oil to settle back down. Always check your oil level when it is cold.
This is funny to those of us who own older 911's. With those cars, you always check the oil with the engine running and up to normal operating temperature.
Old May 23, 2006 | 02:33 AM
delirium's Avatar
delirium
Are you serious?? my owners manual says to measure the oil when the car is at operating temp. I have an 2004. Is the manual wrong?
When my car is cold, i have all the bars full, all the way up to the max!!!
Old May 23, 2006 | 08:35 AM
rcg412's Avatar
rcg412
never check it when it is cold...
do it a few minutes after using the car at normal operating temparature, if you are >than the mid line (~2-3 bars) you are fine. why risk overfilling it?
Old May 23, 2006 | 09:14 AM
gota911's Avatar
gota911
delirium - No, the manual is correct. Your oil level should be OK! I think 02 Carrera was referring to the 993. While I have never owned a 993, I recall reading that you needed to check the oil on a 993 with the engine running. If someone can verify or correct me about this, please do so.
Old May 23, 2006 | 01:12 PM
delirium's Avatar
delirium
I have hear on other forums that the engine should be cold as well, but that does not make sense to me because if you oil is right in the middle when cold, then it will be low when you are driving right??? I dont get where this discrepency is coming from... grr.
Old May 23, 2006 | 07:33 PM
Bijan's Avatar
Bijan
Providing the oil has time to drain, I get similar reading whethere hot or cold. When engine is stopped at operating temperature minutes is enough, when run and still cold it needs hours to drain. If really cold overnight it might be one bar below normal.
