bulge on sidewall Pzero's
I just discovered a slight bulge on the sidewall of my front passenger side Pirelli Pzero, 18/225 after inspecting due to a vibration at speeds of 260kph. Has anyone experienced this with Pirelli's. Had it on my boxster, but never got a bulge. It's got about 70% tread life. I'll be changing tires soon, what is recommended. In my part of the world, a set of tires for our Pcars can set you back for about $4k. thanks in advance.
Newbies Hospitality Director
Jose - I had two sets of Pirelli P-Zero tires on my C2 and did not experience any sidewall bulges. Maybe you can take the car to a tire shop and get a replacement tire for free, or at least, get a prorated price on the replacement tire. It could be a manufacturing defect. Good luck, and let us know how you make out.
Kumusta Jose?
My right rear Pirelli P-Zero Rosso (about 3 sets ago) developed a blister/bubble on the sidewall after I ran over some road debris. A blister can also develop if you accidentally hit the curb while parking. You should definitely get it replaced as soon as you can -- it cannot be fixed. I would even drive the other car until the tire has been replaced.
With 70% tread life remaining on your other tire, you might be able to get away with just buying one tire although I would recommend you get a new pair of tires. Maybe you can sell the other tire on eBay Philippines?
Edit: Have you Manila guys done any fun runs recently? I loved the pictures from Tagaytay that you posted last time.
Agree with prorammatore, change out is required.
The buldge happens when the structure of the sidewall is damaged, either by running over a pothole, or debris, or clipping a curb.
I had exactly the same issue when I hit a pothole on an off ramp, tire bulged immediately.
No way to fix it other than replace it - and soon - it could blow out at speed in this condition.
Chris.
Chris.
Thanks a lot guys! It's the damn roads over here...I probably couln't tell since I have the sports suspension. I'll have it replaced then just to be safe.
I'll post more pictures soon Programmatore.
