stock bekker changer will not eject cartirdge
I went to change out some cd's as I do often every 2 days or so and it won't eject the cartridge! I have tried cycling disc to see if it will do it then and no. The only thing I can think of that I have not done yet is to cycle the power by unplugging it and reconnnecting and trying to eject after or whatever. If not then it's time for full alpin screen nav and changer. Dammit!
Did you have home made Cd's in there and if so did any of them have a stick on label? Those labels usually peel off when they get hot and could be gumming up the works.
Colin
Colin
I saved this from the Becker board, if the changer magazine will not eject or play.
Push and hold the TP button and the #1 and #3 buttons at the same time for about 8 seconds and the head unit will shut down and this will reset the changer.
Worth a try.
Worth a try.
well I got the magazine out but it is still screwed. I hook it up and it says magazine. I had to take the entire unit apart to get my cd's out. I think I am going to have to send it to bekker or something.
