Anyone running 285/35/18's on rear?
I guess I need to clarify my question. I am asking about the sidewall. The normal sidewall for a 285 section width 18 inch 996 rear tire would be a 30 to equal stock(285/30/18). I am asking if anyone is running a 285/35/18. Which means they are a bit talle (.5 inch) or have a larger diameter than stock. If you are running this size are you having any issues with ABS lights and other stuff like that.
Thanks again...
Thanks again...
My Sumitomo's are only available in the 285/35/18 size, so I really did not have a choice.
As stated earlier, no issues. I look at tires as non-permanent equipment. They are going to have to be replaced every 1-2 years, so why pay high rates if you can find a tire that performs similar to the expensive ones.
