996 Forum 1999-2005
Got my car back from the mechanic and they filled my car with 5w-30, is this Ok?
Old 05-16-2006, 10:38 PM
delirium
delirium's Avatar
Default Got my car back from the mechanic and they filled my car with 5w-30, is this Ok?
I just got my car back from the mechanic and they filled my car with 5w-30, is this OK? It is Castrol Syntec 5W-30, should I drain it? Should I have brought my own Mobil 1 0W-40 oil to the shop w/ me? Help, will I destroy my engine?
Old 05-16-2006, 11:07 PM
Torags
Torags's Avatar
Nah, chill. This time of year, with these temps - no problem. If you're in extreme cold the 5w wouldn't flow as well as 0w. I think my 99 probably used 5w-40w. I don't think 0w-40 was made.
Old 05-16-2006, 11:08 PM
mjet
mjet's Avatar
Agree.... No big deal.....
Old 05-16-2006, 11:35 PM
ojpimpson
ojpimpson's Avatar
I have 4qts 5-40 mobil 1 from my 994,I now use 0-40 mobil i in my 996.Can I still use those 4qts of 5-40 as oil to add when I am low in the 996? Thanks
Old 05-16-2006, 11:54 PM
C4 Pazzo
C4 Pazzo's Avatar
It's not the 5 vs 0 you should be worried about, it's the 30 vs 40 (or 50) that should be of concern. Do a search on oil weight and you'll learn more than you ever want to know about the great oil debate.
Old 05-17-2006, 12:20 AM
Ahsai
Ahsai's Avatar
Agree with c4. 30 is too light. Plus Castrol Syntec 5w-30 is not Porsche approved but Castrol Syntec 5w-40 is. Note that the lastest from Porsche approved list are 0w-40 or 5w-40 from various brands.
Hope it helps.
- Ahsai
Old 05-17-2006, 12:51 AM
ojpimpson
ojpimpson's Avatar
My mistake it was 5-30 not 5-40 thanks
Old 05-17-2006, 12:54 AM
programmatore
programmatore's Avatar
What's a 994? Did you have a 995 as well?
Old 05-17-2006, 01:29 AM
delirium
delirium's Avatar
Hope it helps.
- Ahsai
So, what should I do? Drain the oil & refill with 0W-40? I am concerned that I might hurt my engine in the long run!
Old 05-17-2006, 02:02 AM
Ahsai
Ahsai's Avatar
Sorry to say but I would drain and refill with 0w-40 if I were you. A lot of people favor 15w-50 saying that 0w-40 is like water (too thin), let alone 5w-30 (which is even thinner than 0w-40 when hot)!
- Ahsai
Old 05-17-2006, 02:18 AM
LiveNupe
LiveNupe's Avatar
The 994 is one of my favorite Porsches. I'm thinking about selling my 992 to buy one.
Old 05-17-2006, 03:18 AM
delirium
delirium's Avatar
- Ahsai
do i need to replace the oil filter as well? I would think not, since it is new...but its soaked w/ 10W30... or am OK to just drain the oil & refill w/ 0W40??
Old 05-17-2006, 07:17 AM
PDWebb
PDWebb's Avatar
The filter should be fine to stay in. Being soaked in that weight oil won't matter. That'll just "wash" out with the other oil.
Old 05-17-2006, 08:53 AM
jim3
jim3's Avatar
Personally I'd go back to the shop and advise them you expect them to replace with the factory specified oil, but if you drain the oil yourself, drain into a clean container and save for your other cars most of which specify 5w-30.
Old 05-17-2006, 09:13 AM
rountreed
rountreed's Avatar
I agree they filled it with the incorrect oil so it is their responsibility to correct the mistake for free
Quick Reply: Got my car back from the mechanic and they filled my car with 5w-30, is this Ok?
