996 Forum 1999-2005
Convertible top occasionally refused to open/close
Old May 12, 2006 | 08:08 PM
dammad's Avatar
dammad
Question Convertible top occasionally refused to open/close
My 1999 996 occasionally refused to either open or close the top. Instead, the little convertible warning light falshes a few times and I hear a couple of relay clicks from the back.
I've tried ensuring I'm in park and that the brake is pressed, etc. Since I expect there are a few switches to prevent you from erroroneously operating the top whiel moving, but this does not seem to help. Also stopping/starting the engine doesn't seem to help either. Only after driving around a little will the top operate again.
I'm suspecting there is some microswitch somewhere that is telling it that the top shouldn't operate, but apart from the brake/'in-park' switches I'm lost for where else to look.
Any ideas?
Old May 12, 2006 | 08:10 PM
programmatore's Avatar
programmatore
You engaged the parking brake but are you sure the parking brake light on the dashboard is lit? If the parking brake light does not come on then it is probably a bad parking brake microswitch.
Old May 12, 2006 | 08:52 PM
Kims996Cab's Avatar
Kims996Cab
The exact same symptoms you describe will occur if the engine cover is not securely closed / latched. Open it, and give it a good slam.
Old May 13, 2006 | 02:33 AM
C4 Pazzo's Avatar
C4 Pazzo
If those recommendations don't work, it might be that the dash switch has failed. You can easily check by unplugging it and substituting one of the others. I had the exact same symptoms and that was my problem.
Old May 15, 2006 | 01:26 AM
dammad's Avatar
dammad
Alas it hasn't done it again over the weekend. I gave the engine cover a good slam on Friday, so may be that was it.
Many thanks for the suggestions
Old May 15, 2006 | 12:22 PM
D-Train's Avatar
D-Train
I had the same situation last fall. Intermittent problem, I took it to the dealer for a trackday inspection and he said everything is AOK ( I assumed he repaired it) then the problem crept up again. They finnaly replaced the motor for the top. It has not happened again
Old May 15, 2006 | 02:17 PM
bet's Avatar
bet
25 Year Member
For what it is worth...I had a 2000 Boxster that had a failure of the top relay that started as intermediate problems with the top opening and closing. It was fixed under warranty at the time. The dealership said it was a very common problem and that Porsche had come out with a new relay sometime in 2001. It would not surprise me if the relay for the 911 and the Boxster are the same.
Old May 15, 2006 | 04:09 PM
wross996tt's Avatar
wross996tt
I'm having the same problem as well. I installed the SmartTop last year and since then I have had failures 3 times. After driving around (even just letting the car sit) the lid would work again. This last weekend it failed again> Iremoved the SmartTop module and it still won't work...not a fuse and it does not work with the key...so it's not the dash switch. Off to the dealer. These intermittent problems are the worst.
