996 Forum 1999-2005
Fuel Indicator Failure Message
Old Jan 14, 2003 | 09:37 PM
Speed's Avatar
Speed
Post Fuel Indicator Failure Message
I just got the following message on my '02 cab with 22k mi.: "Fuel Indicator Failure. Take to workshop." Fuel gauge is at empty with warning light on even though tank is full; oil pressure guage not operating; computer out; tach operating but giving little flashes. Checked fuse for control; seemed ok. Anyone knows what this means? Is car ok to drive until I can get to dealer (apart from keeping tank filled). TIA
Old Jan 14, 2003 | 11:19 PM
Loren's Avatar
Loren
Post
Sounds like the instrument cluster computer has gone whacko. Shouldn't hurt the engine/car but you likely can't believe any of the readings. If you disconnect the battery for about 5 minutes it might reset the computer (you may have to re-enter your radio code too). Might be worth a try?
Old Jan 15, 2003 | 05:10 AM
Pierre's Avatar
Pierre
Post
Had the same problem on my 996 Turbo 2-3 months ago. Brought the car to the shop, and the first tried to only recalibrate the tank sensor. That was only a temporary fix, then the problem came back. So they replaced the whole tank sensor (under warranty, although the car was 1-2 months out of it). Since then, everything's fine.
And yes, the car is ok to drive.
Greetings,
--Pierre
Old Jan 15, 2003 | 12:47 PM
FixedWing's Avatar
FixedWing
Post
Ditto. This is a known problem on the Turbo.
After installing the new sensor and recalibrating the gauge is much more accurate. Now when it says "empty" it really is empty!
S.
Old Jan 15, 2003 | 06:23 PM
Pierre's Avatar
Pierre
Post
FixedWing, you're right! When I brought my Turbo for this repair, they asked me to bring it with as little fuel as possible in the tank. I did my best: there were only 2 liters remaining!... oops! Wouldn't have gone much further...
--Pierre
Old Jan 15, 2003 | 08:08 PM
FixedWing's Avatar
FixedWing
Post
Before they replaced the sender I would regularly go 20 km beyond the estimated zero point. After I probably could not even go one km. Fortunately I decided to test this out a bit at a time else it would have been a big surprise.
For me, it is a critical issue. We get cheap tax-free petrol in Belgium so I'm always trying to make it back to Belgium with the minimum amount left in the tank.
S.
Old Jan 26, 2003 | 09:18 PM
Speed's Avatar
Speed
Post
I went on vacation before I could thank everyone for their prompt responses. I just took the car to the dealer and it turned out the connector for the instrument cluster just got disconnected from the harness. Dealer said if it happened again he'd order a new instrument clujster.
