996 Forum 1999-2005
Leaking fluid from behind the front drivers side wheel?
Old 01-14-2003, 05:07 PM
sojahseh
sojahseh's Avatar
Post Leaking fluid from behind the front drivers side wheel?
It looks to be washer fluid, but I can't be sure. Blue liquid coming out of the bottom of the drivers side front fender. Is this a common thing? Is this where the evaporator tray for the AC is located as well?
Any help helps.
Matt
Old 01-14-2003, 11:14 PM
Loren
Loren's Avatar
Post
Yup... there have been some cracked tanks (assuming you didn't overfill it).
Old 01-14-2003, 11:58 PM
Karl S
Karl S's Avatar
Post
There was also someone from the UK who posted that he had a problem like this a while back. It wasn't the tank that was cracked but apparently one of the hoses that connect the tank to the wiper. There is a plastic T connector that I think was cracked. In any case, the dealer should fix this under warranty (assuming you still have one). Otherwise, I think you have to go in from the wheelwell to get to the parts that need repair.
Karl
Old 01-15-2003, 08:28 AM
Tom 77
Tom 77's Avatar
Post
Happened to me, the hose fell off. The dealer fixed it
Quick Reply: Leaking fluid from behind the front drivers side wheel?
