996 Forum 1999-2005
Lights Issues (2)
Old Jan 11, 2003 | 04:09 PM
Waz996's Avatar
Waz996
Exclamation Lights Issues (2)
I finally moved my a** and decided to change all the burnt bulbs in the car. There were about five of them (2 side markers, 1 number plate, 2 rear parking lights out of four).
1) Should any of you experience that the right side parking lights are always on (while your engine is running and/or after turning the ignition and leaving the key) even though you have not turned the lights on yourself, THIS IS A SIGN THAT YOU HAVE A BURNT BULB. Change the burnt bulb and the lights will NOT go on when you switch off.
2) Does anyone know why a specific bulb keeps on burning even though I just changed it? What shall I do to prevent bulbs burning?
Waz
996 C2 99
Old Jan 11, 2003 | 07:27 PM
willwest's Avatar
willwest
Post
System voltage is running too high, could be alternator/regulator assembly or it could be an intermittently poor, high resistance, to or within the battery itself. Alternator will generate inordinately high voltage peaks with high resistance to the battery.
Old Jan 11, 2003 | 07:41 PM
Waz996's Avatar
Waz996
Post
..So how do i check the above is occuring in my case?
Waz
