HELP, rear seatbelt stuck.
Basic Sponsor
996 C4S Cab, '04.
Put the back seats down for a few things the other day. Popped them back into place, now I can't move the seatbelt from it's closed and locked position on one of the seats. Can't even lower the seatback it's so tight in there.
Sheesh. Is there an easy release, or do I need to take the rear apart?
TIA
TIA
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring
2009 997 Turbo Cab
2018 M2 6sp
Gone but not forgotten
2004 C4S Cabriolet
1999 C2 Cab
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring
2009 997 Turbo Cab
2018 M2 6sp
2004 C4S Cabriolet
1999 C2 Cab
Originally Posted by Eric - Plug Guy
996 C4S Cab, '04.
TIA
TIA
I had the same problem once with my passenger seat belt and as jsaindc pointed out, it's most likely due to the child restaint feature. I pulled out the belt inch-by-inch allowed by the ratchet lock and once I can't pull it anymore, I fed back the slack and repeat the cycle n times untill the thing unlocked. It took me like 45 minutes!.
You have an '04 so the worst is go back to the dealer and get it fixed under warranty.
- Ahsai
- Ahsai
Basic Sponsor
Was not pulled out at all, no child restraint or passenger application. Just seems locked down. So I pushed HARD against the upper part of the seat, and FINALLY got that beast to give back.
Done, THANKS!!!!!
Done, THANKS!!!!!
